Results 1 to 7 of 7
Thread: R1200C Transmission Drain Plug
    On the Road
    Jan 2004
    Bakersfield, CA
    I own an R1150R. I am changing the transmission oil on a friend's 1200C. On the C model the drain plug is on the bottom instead of the side. The Allen wrench size of this plug is bigger than what I have available. Can someone give me the size so I can go purchase one?
    Registered User 85138's Avatar
    Balt Burbs MD
    R1200C xsmission plug
    Phil, it's 14mm. Just verified in garage.
    On the Road
    Jan 2004
    Bakersfield, CA
    Thanks Kevin.
    14mm hex is difficult to find. After three stops I went to a bolt house which had 14mm hex stock.
    Thanks again.
    Phil
    Scooter Trash WildWilly's Avatar
    Aug 2006
    SE Iowa
    I got a 5 pc. set of 1/2 inch drive metric Allens which included a 14mm hex socket at Auto Zone.
    ONE LESS HARLEY 04r1150rs's Avatar
    Jul 2005
    Bowling Green,KY
    I didn't have the right size either but I did have a bolt with the right size head and welded it to an 3/8" extension, works great, only if you have a welder though.
    Richard
    2004 R1150RS
    1984 R80 G/S
    2003 Suzuki DRZ 400S
    BUBBAZANETTI
    Quote Originally Posted by 04R1150RS
    2 14mm nuts on a bolt with a wrench does the trick too if you don't have a welder
    i bought the hex key for mine, only the configuration of the S doesn't allow for it to fit too well, i had to cut it down a bit............
    Balt Burbs MD
    Nice trick w/ the bolts
    I got the 14mm socket key from AutoZone. PepBoys also has a nice assortment. Got also a 17mm for Duc front axle.
