Piaa X1100
gsjay
Active member
I just mounted a set of Wunderluch engine crash bars on my 2002 GS.
Does anyone know if a set of Piaa X1100 will mount up on the bars without hitting the tank or the forks?
thanks,
gsjay:dunno
thanks,
gsjay:dunno
Yes. The light pattern will have a shadow in the center due to "masking" by the front forks/wheel. If all you want is side-road illuination, that setup will work; if you want more light on the center of your lane, a more forward/higher position is desirable.
mully
