Results 1 to 6 of 6
Thread: F700GS Rear Tire size
    My wife's F700GS is going to need tires in the next 2k miles or so. The rear is a factory size 140/80/r17. I have a set of Michelin Anakee Adventure with about 1k miles on them. The front is the same size as what is on her bike now. The back is a 150/70/r17. Can I use this tire as a replacement for the 140/80/r17?
    Will it fit the rim properly?
    Will it fit in the tire space in the swingarm?
    Will it impact the ABS and/or other systems?
    https://www.tacomaworld.com/tirecalc...0r17-150-70r17
    The 150 is less than 1/4” wider per side (.4” total). There is plenty of room for that.
    The 150 is slightly shorter, smaller diameter, more revolutions per mile, speedo even more optimistic.
    Should work fine. Just remember that you will be going slower than the speedo reads.
    My wife always rides slower hence the reason for GPS that displays actual speed.
    Thanks for the input
    #13338 PGlaves's Avatar
    Just like almost all of the 32 BMW motorcycles Voni and I have owned.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    I am running a 150/70-17 on my F700GS now. I can detect no real difference in handling. Here are the sizes of the two tires:
    The speedo on my F7 is the most inaccurate one Iíve ever experienced on a BMW; 5 MPH too optimistic at an indicated 75 MPH. I rely on a GPS as a speedo and havenít noticed if the indicated speed is more accurate.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    Thanks all it looks like I am good to go. Now when I pull the tires I can fix the TPMS.
  1. 2004 R1100s rear tire size
    By carfont in forum Oilheads
    Last Post: 02-03-2020, 05:31 PM
  2. 1984 R100RT - auxiliary light and rear tire size
    By waishiunyc in forum Airheads
    Last Post: 10-28-2018, 02:40 PM
  3. Replies: 17
    Last Post: 10-20-2018, 02:19 PM
  4. Rear Tire Size/Fit
    By itchy in forum Airheads
    Last Post: 07-23-2010, 03:22 AM
  5. Best rear tire/size?
    By Sportrider in forum Airheads
    Last Post: 03-26-2007, 03:54 AM
