Results 1 to 6 of 6
Thread: Heated Sargent Seat...NO HEAT!!!
    Aug 2006
    Scranton, Pa.
    22018 R1200RTW with Sargent seat. Wires/connectors attached to front and back seat with electrical line running into the bowels of the bike. Have tried the wonder wheel, gone to seat heat section and turned it up to max. No heat, front or back; turned on rear seat with no heat at all; turned on both front with wonder wheel and back with switch, NO HEAT AT ALL ANYWHERE!!! wtf!!!!!!!!!!!
    Wires are in good condition with no cracks, splices or add ons. Thanks in advance
    Will
    Debbie's Servant Lee's Avatar
    SW Iowa
    Is this a new bike for you?
    Did the seat work before?
    I'm guessing the bike has to be running before the heat will turn on.
    Lee
    2022 R1250RS
    MOA # 30878
    Past BMW Bikes: 2016 R1200RS, 2011 K1300S, 2003 K1200RS, 1991 K75S, 1987 K75T, 1984 R100RT
    Massachusetts
    I donít think itís a plot.
    There are a number of factors involved in having the seat work along with the bike, so it seems, needs it to have come with a WORKING original factory heated seat.
    Pretty good write up from the Owners News here- https://www.bmwownersnews.com/2023/0...ntroller-more/
    "You can do good or you can do well. Sooner or later they make you choose". MI5
    Moderator Team.
    2009 F800GS 1994 TW200
    Aug 2006
    Scranton, Pa.
    I spoke with the rep from Sargent seats who told me that the most likely reason that neither the front or back of the seats heat is the likelihood that the bike threw a code which caused the Canbus system to get it's panties in a bunch, which, in turn, caused Canbus to shut down the circuit, killing the seat heat function. Does anyone have any ideas about this?
    Many thanks in advance for any assistance here.
    3hawks
    On the positive side, do u like the seat?
    Jan 2016
    DFW
    Quote Originally Posted by willhawks View Post
    3hawks
    I have the heated seat from Sargent that plug into the canbus. They worked until recently when I accidentally wiggled the wiring on the driver's seat too much. This caused the canbus to throw up error. I wiggled the wires again and all is good.
    So it's not the seats or the bike. Just check the plugs and wires.
    2010 R1200RT, 2022 G310R
    Sargent Low Heated Driver Seat
    2007 Burgman 400 - Sold
    Now DFW, TX, used to live - Vancouver, BC
  1. Heated Sargent seat
    By k75sprint in forum Flying Brick K-bikes
    Last Post: 10-03-2008, 02:55 AM
  2. How much heat is too much heat?
    By jpk1100 in forum Flying Brick K-bikes
    Last Post: 08-19-2008, 01:29 PM
