Results 1 to 15 of 15
Thread: Constantly being logged out of bmwmoa.org
    Jun 2022
    Bel Air, MD
    For a number of weeks now, I seem to have to constantly re-login to bmwmoa.org. Sometimes it's within minutes, and sometimes within days. Previously I would stay logged-in for long periods of time. And yes, I always check "Remember me".
    Has something changed at bmwmoa.org or is this on my end? I'm not aware of any changes on my end and don't see this issue with other forum sites.
    TIA, John
    2020 R1250R Exclusive Pollux
    #13338 PGlaves's Avatar
    Data point of one; I have virtually never had to log back in unless I get a new computer.
    Liaison 20774's Avatar
    John -
    Nothing has changed on the MOA's end. You might try logging out on purpose and see if that helps clean up the cookies...also go to the main website and log out there as well. Also, there's a way to use setting in the browser to clear cookies for specifically the MOA forum.
    Massachusetts
    Quote Originally Posted by jpcarroll View Post
    TIA, John
    Some first things to try-
    Try clearing your history/cookies from your browser.
    If you are using a desk or laptop, how does it react with your smartphone?
    Try using a different device- other than your own and see what happens.
    Some people never log out and things stay "stable". Some log in and out and this can result in a problem like you describe.
    Let us know how you make out.
    "You can do good or you can do well. Sooner or later they make you choose". MI5
    Moderator Team.
    2009 F800GS 1994 TW200
    Registered User kbasa's Avatar
    Sonoma County, California
    If you have your browser set to reject cookies, the site won't be able to recognize you.
    Did you turn on all the security stuff in your browser? Because rejecting cookies will cause exactly what you're describing to happen.
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    Don't forget to choose the "Remember Me" box.
    Jun 2022
    Bel Air, MD
    Thanks for tips. I'll trying logging out and clearing cookies.
    Jun 2022
    Bel Air, MD
    I see the message "All cookies cleared" after a deliberate log-off. I had browser tabs logged into different areas of bmwmoa.org. I logged out of all of them. Will see if this resolves the problem.
    Up until recently, I rarely was forced to re-login.
    Mar 2006
    Raleigh NC
    For some unknown reason, Iím always prompted to sign in when I load the MOA page, which I never do, and I always show as signed in on the forums page. Go figure.
    Doug
    Sent from a Galaxy, far, far away
    Massachusetts
    Quote Originally Posted by 83014 View Post
    Doug
    BMW MOA- https://www.bmwmoa.org/default.aspx is one address.
    Forums BMW MOA- https://forums.bmwmoa.org/forum.php is one address.
    Each require a separate login to view the complete sites.
    If you are having trouble with either sites, try the above hints.
    Moderator Team.
    Jun 2022
    Bel Air, MD
    Less than 24 hours since I logged-out of all my bmwmoa.org tabs, and only logged back into one tab for this forum, I just got logged-out again.
    I'll try manually clearing cookies.
    Edit:
    Logging out said "all cookies cleared". In Chrome, I found 164 cookies associated with bmwmoa.org and I've deleted them and re-logged in. Will see what this does.
    OK, so you know, here's how cookies work. They're a tracking object and if the MOA site doesn't see a cookie it placed there or your browser won't let it set a cookie, it will forget who you are.
    Clearing cookies may be exacerbating your issue. If you're using a browser and you've disabled cookies, the site won't be able to "remember" who you are. I use a Mac and in Safari settings, there's a Privacy tab with "Block All Cookies". It's unchecked because if I checked it any site that uses a cookie to remember me will be broken.
    I'd start diagnosis here: "Is your browser allowing the MOA site to set cookies". It needs to be able to do that or it'll keep logging you out when you change pages and the site looks to see who you are.
    I hope that's helpful.
    Dave Swider
    Marin County, CA
    Jun 2022
    Bel Air, MD
    Quote Originally Posted by kbasa View Post
    Thanks Dave, I know how cookies work. And as I noted in my OP, I haven't made any changes to cookie handling. I do not have "Block All Cookies" checked and MOA is not prevented from setting cookies. Since re-logging in, bmwmoa.org has generated 25 new cookies, so this isn't the problem.
    A setting of interest that is enabled under Chrome "Performance" is the "Memory Saver" which is supposed to free up memory of inactive tabs. I have a good many tabs open in a number of Chrome windows. I wonder if this was affecting the login status if the bmwmoa.org tab had it's memory freed. Description just says tab is active again when selected...not very informative. Anyway, there's an option to add sites that will always remain active and I've added bmwmoa.org
    I'll report back...
    I'll report back...
    Good luck, man.
    Dave Swider
    Marin County, CA
    Jun 2022
    Bel Air, MD
    It's been 9 days since adding bmwmoa.org to the Chrome Memory Saver "sites that always remain active", and I haven't been logged-out since.
  1. 87 k75s CONSTANTLY (every ride) cleaning the injectors - HELP
    By jimnto in forum Flying Brick K-bikes
    Last Post: 04-22-2023, 10:41 PM
  2. 1992 K75S ABS light constantly on
    By broadstone in forum Flying Brick K-bikes
    Last Post: 11-13-2012, 08:04 PM
