Results 1 to 5 of 5
Thread: Condensation from Pipe Connection During Startup - Normal or RT Silicone?
    Jan 2020
    Philly Suburbs, PA
    I had taken off the factory exhaust and put it back on. Now I notice some condensation coming down exhaust pipe at the connection between muffler and exhaust pipe. Once bike heats up, it goes away. Should I put some High Temp RT silicone at the connection or is this not a problem.
    Thank you!
    Massachusetts
    Condensation/water vapor seems to be a byproduct of the new emissions systems. I wouldn’t worry about it unless it results in a stain- which is possible.
    There is a possibility that this is “seasonal” and may change when temperatures are more equal.
    Usually the High-Temp silicone (red) is used in this type of sealing but could easily end up being more of a mess than the drip.
    Chances are there is a low-point drain in the exhaust system.
    Good luck.
    "You can do good or you can do well. Sooner or later they make you choose". MI5
    Moderator Team.
    2009 F800GS 1994 TW200
    Jan 2020
    Philly Suburbs, PA
    Red silicone worked. Hope I never have to take muffler off since it looks impossible to do so with the silicone
    Nov 2011
    Central Ohio
    I'd rather have condensation outside the exhaust system than inside. Hopefully, there is a drain at a lower point.
    Larry
    2006 R1200RT
    Dec 2007
    Indiana
    Quote Originally Posted by Zwniana View Post
    Thank you!
    Some models do require muffler movement for wheel access. There is usually a small hole to allow moisture escape from inside the exhaust pipe or silencer, especially useful and noticeable in cooler weather when more condensation takes place. Have had numerous bikes with obvious "dip" hole at lowest point of exhaust system.
    MOA #46783
  1. Replies: 4
    Last Post: 09-23-2008, 06:05 PM
  2. Silicone in Handlebars?
    By R100RS in forum Gear
    Last Post: 12-03-2006, 01:24 AM
  3. silicone or copper ignition wires?
    By ISAMEMON in forum Airheads
    Last Post: 08-29-2006, 01:48 AM
  4. Y pipe or Pre-Pipe (collector)?
    By screwtop in forum Oilheads
    Last Post: 06-08-2005, 06:03 PM
  5. Silicone Gaskets
    By TZOLK in forum Airheads
    Last Post: 03-09-2005, 04:03 PM
