Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
The 28 teeth on the splined flange is correct for a /2 (R50; R50/2; R60; R60/2; R69; R69S.). 4 options from what I can tell on the crown gear sets, if no stamping you'd have to count the teeth, 27:7, 27:8, 25:8, and the sidecar rig had 26:6.
To determine the ratio, I think it takes more than counting the teeth. Pick one of the teeth and turn the final drive exactly one revolution while monitoring how many turns the u-joint at the front of the drive shaft turns. Those number of turns of the front joint will let you figure out what the ratio is. It will be something like three full turns so 3.0/1 or 33/11. If it's slightly more than three full turns, it could be 3.125 or 25/8.
I've asked the seller to try to count the ratio by rotating the input. But the difference between 3.125 (25/8) and 3.375 (27/8) might be hard to distinguish.
Further info I've read indicates this is likely a pre-war final drive or possibly for one of the early R51 plunger bikes and may have been a replacement.
