'05 R1200 ST "threaded pin" on rear sub-frame ?
RANBUSH
Ran Bush
I'm trying to replace the clutch on my '05 R1200 ST and as many of you may know, you have to take the damn bike apart to get to the clutch. I have the BMW Shop Manual, and it says that to take off the rear sub-frame, I have to remove Bolt 1, then tighten a "threaded pin" on each side, and then remove Bolts 2 and 3 to release the sub-frame. Then Bolt 4 is loosened.
The pin is shown in the attached JPG. I can't find it, either on the bike or on the Max Parts fiche. Does anyone where the pin is hidden, or know the full part number?
I can't find it using the six digit number in the JPG, I need more numbers. I also can't see it in the Max Parts fiche rear sub-frame parts list.
TIA.
A gentleman on the ST Forum replied: "That 46 5 691 is a BMW special tool not a motorcycle part. It's hidden in the BMW special tools list."
Mystery solved? I'll let you know.
When I replaced the clutch in my 2007RT I borrowed a set of these from a friend who made them from a bolt of right size and length Cut off the head and saw a slot in one end so you can screw it into place.
Thanks for the idea, Dave. I just had a friend come over and we drank beer and yanked on the subframe until it came apart.
What could go wrong?
8D
