Results 1 to 7 of 7
Thread: Light Rust in My Tank
    Sep 2006
    Washington State
    What is a good procedure , removal and sealer. Light, no big flakes.
    Liaison 20774's Avatar
    I'm facing probably the same thing on my R25/2 tank. I haven't gotten into it yet, but I plan to use Evaporust to attack the rust in the tank, then follow up with an etching and sealing kit from Caswell Plating. That's my plan, anyway.
    Snowbum has a discussion of tank cleaning and sealing near the top of this page:
    https://bmwmotorcycletech.info/fuelmiscl.htm
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    I have rust issues in my tank as well from it sitting too long. I feel that this is a one-time shot and if it's messed up, I'm not sure it could be redone. And, new tanks are no longer available from BMW. I'm hoping to find someone who will do it at a reasonable cost.
    Jeff
    1988 R100 RT (the other woman)
    2018 R1200 GS (the mistress)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    + 1 on Evaporust, but it works best when the part is submerged. Sloshing it around is much less effective.
    New, painted tanks are available from India for less than $300, but use a non-stock appearance gas cap.
    -Live as fully as you can as long as you can-
    Registered User kinterridge's Avatar
    Jul 2017
    +1 on Evaporust, I use two gallons in a tank with holes plugged or capped. At least 2 days on all six sides, left, right, top, bottom, front, and rear. It'll remove light rust just fine then re-line. Harbor Freight is the least expensive place I can find the Evaporust in gallon jugs. If the tank is a basket case there's a shop in Greensburg, PA that will open the tank, make it like new inside and re-line it. They send it back welded back and lacquer primed.
    Dave Hutton '78 R100S (MFG 7/77) '71 R50/5 '01 K1200LT
    Registered User rikb's Avatar
    Feb 2016
    Oakland, CA
    Quote Originally Posted by kinterridge View Post
    thanks @kinterridge, just getting into issues with the tank on my '86 R80. A couple of questions:
    - any hints on what sort of plug do you use for the top refill hole?!
    - my tank has two extra (beyond the 2 for the petcocks) holes. (see attached photo).
    i think they were for some emission requirement in the past?!
    - can you pass along the contact for the shop in Greensburg PA please?
    thanks! - Rik
    '86 R80, ('00 R1200RS, RIP), '15 R1200R
    Apr 2006
    Nibley, UT USA
    Quote Originally Posted by 88bmwjeff View Post
    I also have a tank that needs relining, but it’s not rusty—yet. If you find a reasonably priced vendor who does quality work relining these, please post it here in the forum. Thx!
    Best,
    DeVern
    DGerber
    1983 R80ST — 2010 K1300GT — 2018 R1200GS
  1. Rust in gas tank
    By gracie in forum Airheads
    Last Post: 01-24-2022, 10:15 PM
  2. Replies: 8
    Last Post: 06-03-2010, 06:38 PM
  3. Exterior (Underneath) Gas Tank Rust
    By barron_williams in forum Airheads
    Last Post: 03-22-2010, 04:33 AM
  4. Gas Tank Rust removal and reseal
    By rkildu in forum Airheads
    Last Post: 12-17-2007, 01:52 PM
  5. Gas tank rust.
    By jmerlino in forum Airheads
    Last Post: 02-06-2006, 04:13 AM
