Results 1 to 11 of 11
Thread: Inner Timing Cover Gasket With Or Without Gasket Sealant?
    Aug 2004
    Walnut Creek, CA
    I hope this doesn't become a thread with a lot of opinions, but should I install the gasket for the inner timing cover dry or with gasket sealant?
    Jeff
    2018 R1200 GS (the mistress)
    Liaison 20774's Avatar
    Snowbum says in a couple of places on this page to not use any sealant. Search the page for "sealant".
    https://bmwmotorcycletech.info/timingchain.htm
    Aug 2004
    Walnut Creek, CA
    I watched a video from Boxer2Valve and he uses sealant. But, I'll go with Snowbum here; as such, I'm leaning towards no sealant.
    Jeff
    What does that Boxer2Valve know!! Tough call, opposite info from solid sources.
    I tracked down an Airheads airmail post where Tom Cutter says no sealant.
    But there are a couple of tiny circular gaskets used on the top two holes.
    Manitowoc, Wisconsin
    Just my nickel's worth - a few years back I did the same job with the engine in the frame. I used some gray sealant, not as a sealant, but just a little as an adhesive to keep the gasket (including those two circular pieces) in place while installing the timing cover. Made getting all the fasteners in place easier without messing up the gasket.
    F.O.G.Rider, Rounder #6,
    Ambassador, WI Airmarshal
    BMWRA Wisconsin Region Rep
    What's the final decision? The usual crowd at Boxerworks seems to like using some kind of sealant/paste.
    Massachusetts
    FWIW, if it requires sealer, I apply the sealer accordingly. If it doesnít require sealer, I apply sealer as a way of holding the gasket in placeÖ.. Usually something like Permatex Ultra Black.
    If I want it to be adhered without fasteners, itís Indianhead shellac
    "You can do good or you can do well. Sooner or later they make you choose". MI5
    Moderator Team.
    2009 F800GS 1994 TW200
    Aug 2004
    Walnut Creek, CA
    I'm going to skip on the sealant. I was surprised about the recommendation to use grease or oil to hold the gasket in place. I was planning on using a bit of grease to hold the two round gaskets at the top. I'm leaning towards using a thin coat of grease or oil to hold the gasket in place. However, that task will be for the upcoming weekend.
    Kurt, thanks for your posts on both sites.
    Jeff
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    No
    All the times I have installed new chains, I have not used a sealer. The two little bitty gaskets are tricky to keep in place I may have used a tiny drop of something to keep them in place. St.
    Nibley, UT USA
    Quote Originally Posted by STEVENRANKIN View Post
    Iíve never used a sealer either. The big gasket isnít too tough to keep in place and a shot of 3M spray adhesive works well on the two small round gaskets.
    Best,
    DeVern
    DGerber
    1983 R80ST ó 2010 K1300GT ó 2018 R1200GS
    Spencerport, NY
    thanks
    Thanks DeVern for refreshing my memory, I couldn't remember what I used to hold the little guys in place. St.
  1. Replies: 4
    Last Post: 01-29-2023, 09:28 PM
  2. Gasket Sealant
    By lkchris in forum Airheads
    Last Post: 05-14-2012, 12:47 AM
  3. Base Gasket Sealant/Application
    By ebeeby in forum Airheads
    Last Post: 03-28-2010, 02:44 AM
  4. /5 oil pan gasket or sealant??
    By robertklee in forum Airheads
    Last Post: 03-06-2010, 12:21 AM
  5. another gasket/sealant question
    Last Post: 04-30-2009, 01:50 AM
