Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Thread: Helite Air Vests- what do you owner's think of the products?
  1. #31
    Jul 2021
    Las Cruces, NM
    Thumbs up
    Quote Originally Posted by akbeemer View Post
    It should not deploy in a minor fall over.
    Ray Puckett, MOA #225597
    IBA #82538
    '74 R90/6. '75 R90S. '76 R90S. 2019 R1250RT.
    Too many dirt bikes.
  2. #32
    I was given the Helite vest for Christmas last year and I have yet to wear the thing one time. I did install the tether on my bike. Every time I think about wearing it it just seems like it’s going to be a pain in the a$$ to deal with it. I am sure it would provide a margin of safety but I just can’t get use to the idea of strapping myself in and out all the time. Must be a psychological problem I have.
  3. #33
    Central Ohio
    I bought my Turtle at the SLC rally (10%off and an extra CO2 cartridge). Since then, I've ridden exactly one time without it. I've considered leaving it at home at times, but then think about how totally stupid I would feel while healing from an injury the vest could have prevented. But then, I always wear a helmet and I always buckle my seat belt when driving, too. I guess if I knew when I would be having an accident I could leave the gear at home the rest of the time.
    Yes, it's a bit heavy to put on and off, and one more thing to deal with at a stop, but that has just become part of the routine. It goes in a pannier or top box when I park, or is cable-locked with my helmet and jacket when the luggage is full. I'm never aware of the vest while riding, and it does not seem to reduce air flow while in motion. It might be a bit warmer at a stop - it's hard to tell.
    It's gone off once, when I let my speed drop to zero while making a U-turn and dropped the bike. I was not aware that it had inflated until I noticed it was a little hard to breathe while lifting the bike back up. It all happened pretty quick, but I think I rolled away from the bike when it went down, pulling the tether. I popped my mirror back on, installed the spare cartridge, went on my way. $45 bought two new cartridges.
    I picked the Turtle because it is well-made, effective, and requires little maintenance. It does not require expensive visits to Europe for renewal or re-charging. The vest is more practical for me because I have different jackets for different weather and I can wear the vest with them all.
    Larry
    2006 R1200RT
  4. #34
    Jul 2021
    Las Cruces, NM
    Quote Originally Posted by 54571 View Post
    I've been contemplating a Warm and Safe heated liner to wear under my Kilimanjaro jacket. Seems like a great idea. I am resistant to being plugged-in (tethered) to the bike. I can foresee potential disasters. Must be a psychological problem I have.
    IBA #82538
  5. #35
    Registered User zenwhipper's Avatar
    Apr 2016
    Seattle, WA
    Yes!
    I have used the Hit Air for 10+ years. These devices are extra insurance against injuries in a crash - should you ever draw the joker card. Just like other things to make sure you're safe(er), extra lights, hi-vis helmet, ATGATT, ABS, traction control etc etc. Why not? What have you to lose.
    “I do not fear death. I had been dead for billions and billions of years before I was born, and had not suffered the slightest inconvenience from it.”- Mark Twain
    Past bikes: 2001 Kawa ZR750S, 2002 VFR, 2006 V-Strom, 2008 FJR
  6. #36
    Nibley, UT USA
    Quote Originally Posted by craydds View Post
    I've been contemplating a Gerbring or Warm and Safe heated liner to wear under my Kilimanjaro jacket. Seems like a great idea. I am resistant to being plugged-in (tethered) to the bike. I can foresee potential disasters. Must be a psychological problem I have.
    Modern heated gear uses coax connectors that pull apart quite easily and would not bind you to the bike in the event of something unexpected. On my GS, I have to remind myself to leave sufficient slack so I can stand on the pegs without unplugging the electrics, and on those occasions I’ve forgotten to unplug before heading off to a restroom there’s only an almost unnoticeable tug as the cable disconnects.
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2010 K1300GT — 2018 R1200GS
  7. #37
    Mar 2011
    socal
    I have a hellite jacket, purchased a year ago, worn on every ride till zipper gave out. Sent back to service center in Reno. Took a month but when it came back they had installed a very heavy duty zipper instead of the el cheapo that came on jacket
    I consider it a good investment
    Jim
  8. #38
    Registered User crna59's Avatar
    Apr 2017
    Snohomish, WA
    I started with the first Street AlpineStars TechAir that zips into the jacket. I purchased a Spring/Summer jacket and a Fall/Winter one. The only downside is that it is a little heavy. I had numerous other jackets hanging in the garage and purchased the stand-alone TechAir 5 that can be used under any jacket. It's much lighter than the older model, but the downside is that I can't just look at my wrist to see if it is armed. I can pull out my phone, but that's a PITA. Wouldn't ride without one now.
    Bruce A. Brown #212072
    MSF 2-wheel Instructor
    H-D Riding Academy Instructor
    S/TEP 3-wheel Instructor
  9. #39
    Jul 2021
    Las Cruces, NM
    Quote Originally Posted by GTRider View Post
    Best,
    DeVern
    Good to know. Thanks, DeVern!
    IBA #82538
  1. Air Vests By FortNine
    By akbeemer in forum Gear
    Last Post: 05-31-2022, 05:01 PM
  2. Replies: 1
    Last Post: 02-04-2017, 01:14 PM
  3. Air bag vests
    By janda in forum Gear
    Last Post: 08-10-2015, 01:27 AM
  4. Replies: 3
    Last Post: 12-13-2013, 02:20 PM
  5. phase change cooling vests or water evap cooling vests?
    By DG123 in forum Flying Brick K-bikes
    Last Post: 09-21-2006, 12:29 AM
