Results 1 to 2 of 2
Thread: Wunderlich F850 GSA Shift Assist Protector Install
    I bought this product and want to install. There is the main larger cover plate and a small angle bracket/plate that bolts onto it on the back side. They include a 3/4” by 4” stripe of thin foam with self adhesive back. And a 1/2” by 2-3” harder vinyl or rubber self adhesive strip. The instructions related to placement of the padding are very unclear. I expected more from a German company. The diagrams suggest that pieces of the thin foam be placed on the main plate and smaller angle bracket so that they face each other. But once you start to bolt the smaller angle bracket on these two pieces of foam would never touch each other. Conversely, the part of the angle bracket/plate that might rest against the MC housing shows no foam or rubber strip being placed on it. In fact, based on the diagram pictures it is not clear what the harder rubber self adhesive part is used for. I suppose I could just use my best judgement, but after spend $95 for the part I would like to place it properly.
    Yes, I have sent an email to Wunderlich several days ago with no response as yet.
    If anyone has installed and figured out how to use the foam or rubber properly I would appreciate knowling. Thx, stephen
    More toys than space mcmxcivrs's Avatar
    Calgary
    The instructions that came with mine show putting a small square of the foam on the small bracket where it would contact the back of the footrest plate and a small square of the rubber pad on the main guard piece where it will contact the foot rest bracket. The purpose of the small bracket is to clamp the main guard to the footrest bracket through the opening. The main guard on the outside and the small bracket on the backside.
    Ed Miller, Calgary, AB
    1994 R1100RS, 2019 F850GSA, 2023 R1250 RT
  1. Replies: 3
    Last Post: 02-09-2022, 10:46 PM
  2. F850 GSA - OEM VS BDCW Skid Plate
    By rwadamsidaho in forum F-Twins
    Last Post: 03-07-2021, 03:20 PM
  3. Replies: 1
    Last Post: 02-06-2020, 10:49 PM
  4. Shift Lever Adjust with Shift Assist - How?
    By BeemerMike in forum Wedge K-bikes
    Last Post: 10-12-2018, 03:10 PM
  5. Replies: 17
    Last Post: 04-11-2011, 08:23 PM
