Results 1 to 8 of 8
Thread: Can Bad Gas Cause Engine Light to Come on and Fault Code "Detected Misfiring"?
    Oct 2022
    Bakersfield, California
    Hello,
    Has anyone experienced potentially bad gas causing stalling, rough idle and a flashing engine light to come on?
    The fault code stated "Detected Misfiring". I changed out the gas, cleared the code and it is slowly running smoother. I hope it was the gallon of gas I put in that was in my garage for about 6-8 months (87 octane from California)
    Just curious if anyone had a similar experience, especially with the fault code.
    Thank you!
    Sean
    #13338 PGlaves's Avatar
    Quote Originally Posted by seank View Post
    Hello,
    Thank you!
    Sean
    I am not sure about the ability of the BMW system (on your model) to detect it but bad gas can ABSOLUTELY cause stalling, rough idle and engine damage too, on top of all of that. I had a very good friend (RIP) who owned a motor home with year old gas. It started misfiring when he went to move it and the end result was a $3,000 engine repair. On bikes, bad gas will almost always result in misfire, sluggish acceleration, and other maladies. My advice - get it out with a siphon hose before it causes significant damage. This is especially true of any fuel adulterated with ethanol.
    What Paul (above) said ... plus that's a great way to learn that lesson. I know I have gas sitting in cans in my shed that's got to be at least that old. I should get rid of it ... but where do you get rid of old gas? Plus I know at least one of the cans is mixed with oil for my two-stroke leaf blower. I know I can't just dump it in the culvert. Maybe my local recycling/dump station will take it, I know they take oil and other substances.
    Your MOA Digital Media Editor since 2015 | Lifetime Member #87301
    '15 R 1200 GS | '76 R 90/6 | '19 Indian FTR1200S
    Check out Chasing the Horizon, a podcast by, for & about motorcyclers
    Massachusetts
    Quote Originally Posted by chiba View Post
    In your car would be a good place to use it. As long as itís free of crap, any loss in potency will blend just fine with the vehicleís volume.
    Thatís my experience.
    "You can do good or you can do well. Sooner or later they make you choose". MI5
    Moderator Team.
    2009 F800GS 1994 TW200
    Massachusetts
    Hello,
    Thank you!
    Sean
    This question is related to this posting- https://forums.bmwmoa.org/showthread...odes-for-GS310
    Good luck.
    Moderator Team.
    May 2006
    Northern New Jersey
    Itís said that gas starts to degrade after just one month if it contains ethanol. Non ethanol gas *may* stay fresh for 3 months or a little longer. Not completely unusable then, just ďgoing badĒ.
    6-8 months is way too long without Stabil being added when fresh.
    What happens is itís composition changes over time and it loses some of itís volatility. (The volatile components evaporate). Once all of your bad gas is gone, either by using it up, or by siphoning it out, and fresh gas replaces it, you should be good.
    "The two most important days in your life are the day you were born, and the day you find out why" -- Mark Twain
    Registered User slowpokepete's Avatar
    Aug 2020
    Hillsdale, NY
    Quote Originally Posted by ClassicVW View Post
    Itís said that gas starts to degrade after just one month. Not unusable then, just starting to go ďbadĒ. 6-8 months is way too long without Stabil being added when fresh. What happens is it loses some of its volatility, and itís composition changes over time.
    Just picked up a bottle of Sta-bil to get ready for the off season for stored gas...keep in mind that according to the bottle, once it's opened it's good for two years.
    There's a place on the label to write the date when opened.
    SPP
    Member # 222067
    May 2006
    Northern New Jersey
    Quote Originally Posted by slowpokepete View Post
    SPP
  1. Excessive "Fault in the Engine Control" Warnings
    By tmwilmotte in forum Wetheads
    Last Post: 08-22-2021, 08:42 PM
  2. Replies: 12
    Last Post: 08-24-2018, 11:59 PM
  3. '92 K 75s Almost Constant Misfiring, Bucking, and Popping.
    By 72r60/7 in forum Flying Brick K-bikes
    Last Post: 05-07-2014, 03:47 AM
  4. 05 R1200GS Headlight fault code
    By 129974 in forum Hexheads/Camheads
    Last Post: 04-05-2011, 04:53 PM
  5. Bad Bad Bad GS!
    By redclfco in forum Campfire
    Last Post: 05-24-2008, 11:56 AM
