Results 1 to 8 of 8
Thread: S1000XR Starting Issues
    Unhappy S1000XR Starting Issues
    Hello all Hotheads,
    I have a 2021 XR with less than 600 miles on it. I just love this machine......when it starts. Here's the symptoms. I go out to start it and it behaves like it has a dead battery with a slow womp, womp, womp and dead. Meanwhile lights are nice and bright and TFR is on brilliantly. I shut the ignition off and walk away for a couple of minutes. Try it again and it happens again. Wait another ten minutes and vvvvrrroom, she starts. Not only does it start, it starts with vigor. I have already got a replacement LiI battery under warranty. Same problems. I've double and triple checked my connections. Same problem. My battery minder is an Optimate 1 LiI approved minder. I am at wits end with the obvious. I put a meter on the battery and it's right where it should be. Any thoughts out there?
    Thanks in advance.
    Massachusetts
    Welcome to the forum!
    Are you riding the bike every day?
    Are you charging directly to the battery or through the accessory port?
    "You can do good or you can do well. Sooner or later they make you choose". MI5
    Moderator Team.
    2009 F800GS 1994 TW200
    Routine
    Hi,
    I'm charging through a trickle charger two prong cable attached to the battery. I do not ride daily at this point.
    Massachusetts
    A friend of mine gave me an Optimate charger……really nice but I keep forgetting how the settings work. Direct to the battery is the best way as far as I’m concerned.
    Many of the members have that charger and can maybe go over the operating sequence with you. If you could take it for a ride every day, it would be another way of testing the charger operation as well.
    Let us know how you make out.
    Moderator Team.
    Okay. Will do. I don't think its the charger or even the battery but not certain what else to tackle. I'll circle back at some point.
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Quote Originally Posted by ranjam View Post
    Hello all Hotheads,
    I have a 2021 XR with less than 600 miles on it. Any thoughts out there?
    Thanks in advance.
    Two Words: Dealership. Warranty!!
    A virtually new bike that doesn't start? Those two words! Plus these two words: Roadside Assistance!
    If you haven't yet, check the tighten the terminal nuts. That's exactly the symptom of a loose ground nut. If that doesn't work, try switching the bike on and waiting a bit before hitting the starter. Sometimes letting the battery 'warm up' a bit increases the CCA available. To be sure, if the latter works there's a problem somewhere.
    '13 690 Duke, '19 Ninja 400 (track bike), '21 Duke 890R, '22 Street Triple RS, '22 S1000XR. '22 R7 (track) (gone but not forgotten: '61 Clubman's Gold Star, '76 R75/6, '84 R100, '76 R90S, '20 R1250R)
    Quote Originally Posted by ccolwell View Post
    Thanks. I'm going to try it but I think I'm going to end up going down the dealer route for warranty. Was hating that option but alas, it might be time to cave.
  1. ‘85 K100 Starting issue (actually a non starting issue)
    By DWEBB49 in forum Flying Brick K-bikes
    Last Post: 02-08-2022, 04:33 AM
  2. Starting/High RPM Issues
    By GREGT1 in forum Airheads
    Last Post: 06-23-2010, 05:36 AM
  3. '02 R1100S Starting Issues
    By DrGonzo in forum Oilheads
    Last Post: 03-13-2010, 04:29 PM
  4. Starting issues and questions
    By rkildu in forum Flying Brick K-bikes
    Last Post: 03-01-2010, 10:20 PM
  5. R1150R Starting Issues ?
    By dlearl476 in forum Oilheads
    Last Post: 05-17-2005, 03:00 AM
