Hello! I'm a R1150GS owner that's just got into a unloved 03' K1200LT which came to me with the ABS already bypassed. The speedo and stop lights weren't working. Some reading and digging and I found the ABS wiring harness wasn't plugged in the ABS brain. I plugged it in and the speedo started working, but the brake lights are on solid, activating the front or rear brakes doesn't affect the brake light. It won't shut off. The ABS motor also buzzed when I first plugged the harness onto the ABS unit, but after I switched the key on and off a few times that motor buzzing stopped. So, I did a search here but that didn't show me any removal articles.
Has anyone successfully removed the ABS and had the brake lights, speedo and cruise work afterward? I'd appreciate your ideas.
Markus
2002 R1150GS
2002 R1100Rt
2003 K1200LT
