gs911 issues
slowspoke
Bought a 2013 r1200gs a year ago and a gs911 tool, changed oil and reset system also woke up tire pressure system and got that working. Today I changed oil and the gs911 says needs updated to a yellow version, the 1 I have is red with round connector and is wifi
I follow all the downloads and prompts and when I go in to select the series of bike it doesn't list the 2013 and up 1200 LC Need help so I can reset the service information
thanks in advance
I just updated mine which is the same model.
1. hooked the gs911 to my windows pc with usb cable
2. went to this link and downloaded and installed the latest diagnostics installer at the top of the page
3. ran the diagnostic utility and chose my gs911 with usb connection
4. chose update software now
5. it installed 3 updates with progress bars in about 10 minutes
Note: always best to have your computer attached to a battery backup for any firmware upgrades. Loss of power during this process could brick your device.
Click "About" to see software versions:
before upgrade I was:
Firmware Version
1.58 - 0.201
Base System Version
0.27 - 0.13 - 4
Data pack Version
176
Device Type
GS-911wifi (10-pin)
after upgrade:
Firmware Version
1.70 - 0.246
Base System Version
0.27 - 0.13 - 4
Data pack Version
221
Device Type
GS-911wifi (10-pin)
then I opened the gs911 app on the pc and it prompted to check for updates because they were over a year old.
1. clicked tools/setup and changed from wifi to usb connection
2. clicked help/about/check for update
3. updated from version 2104.1 to 2208.2
4. started the program and it is gs911 legacy - not wifi
definitely a problem with the update process for this piece of software. Will test some more. and report back.
Looks to me like the stand alone PC version of the software has been deprecated in favor of the web app or diagnostic utility that they have been adding functionality to over the years for the red models. One way to open the web app is to open the wifi utility then click the link in the lower right hand corner to open diagnostic web app in browser. If you don't want to lose the offline PC version for the wifi unit do not update it beyond version 2104 and be aware that no more development is going into this version.
When I updated mine a few days ago it created a new icon & left the old icon on the screen. I kept clicking the old icon because I didn't see the new icon in the lower corner. Once I clicked the new icon it worked fine.
You have the wifi version?
gs911 issue
This was the problem I was having. Clicked on the new icon and all went well. thank you for the help
Good information to know, thank you very much
That didn't happen to me. I just had one icon - for the legacy version - which does not support wifi. When I open it in usb mode it prompts that I should be using the new diagnostic utility instead for my device.
I uninstalled it, then installed 2104 again and updated it again and the same thing happened. This is on a Windows 10 PC. Weird that it is different from your experience.
I uninstalled it again and installed 2104 and won't upgrade that version anymore just in case I ever need offline functionality. I will use the diagnostics app or web app whenever using it under normal online circumstances however.
