Results 1 to 6 of 6
Thread: 86 k75 c weird noise 13 k miles
    Getting used to this new to me K. There is a noise that is worse when cold. Sounds to me like it’s in what would be the bell housing. Sounds like a loose bearing at about 1500. It might be something of concern or maybe not. I know that’s not a good description.
    Thx
    Jeff
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Jeff,
    Is this with the bike moving in gear or stopped with the clutch in or in neutral?
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2006
    Nibley, UT USA
    That sounds like side slap between the gears in the intermediate housing. Most all brick-k bikes acquire that noise sooner or later, and it doesn’t cause any problem other than being acoustically annoying. Quieting it requires pulling the trans and the intermediate housing and re-shimming the gears and is generally not considered worth the time, effort, and expense. The noise is usually only noticeable at idle or below 1500rpm and not noticeable once underway.
    Best,
    DeVern
    DGerber
    1983 R80ST — 1984 R80 G/S-PD — 2010 K1300GT — 2018 R1200GS
    Noise is the same in neutral or in gear. With clutch engaged or not. Pretty sure I’m just going to learn to live with it. Just wanted to be sure
    Thx
    Jeff
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Listen where the alternator mounts at the right-rear of the engine. Hard, stiff, worn rubber cush drive pieces will make a noise.
    Nick Kennedy
    Nov 2011
    Telluride Colorado
    One cheap [ BMW owners' favorite word] and easy diagnostic tool to make, is a section out of a old garden hose, It can be fairly long if needed, like 4'.
    Put one end against your ear and the other in the vicinity of suspected noise and if it's there you will hear it.
    Nick
  1. Weird total miles K1200RS
    By RBEmerson in forum Flying Brick K-bikes
    Last Post: 10-24-2016, 01:41 PM
  2. Weird noise
    By johnnyb in forum Airheads
    Last Post: 09-08-2011, 04:39 AM
  3. a weird one: best glue for re-attaching K75 badge to rear cowl?
    By barooo in forum Flying Brick K-bikes
    Last Post: 07-08-2010, 10:47 PM
  4. weird downshifting on k75 makes me paranoid...
    Last Post: 10-05-2009, 03:49 AM
  5. Wind Noise, I hate wind noise!
    By oldhway in forum Oilheads
    Last Post: 06-09-2007, 10:54 PM
