Results 1 to 10 of 10
Thread: 86 K75 C ( I think). 12k miles.
    My 2nd K bike. Previously owned a K100. Attempting to get her in good shape. Found a break in vacuum hose in the wire loom. Trimmed back and now running much better. Iím thinking she just needs to be risen a lot and keep running good gas and cleaners thru fuel to clean injectors good.
    Couple questions- where can I obtain engine guards?
    2) this bike has the headlight housed in a pod. Does that make this a C model?
    3) whatís the best clear or smoked windscreen out there that will work with this headlight housing? There are a few on Amazon that look ok but IDK.
    4) I am considering getting a headlight modulator to be seen better. Ideas on that?
    5) considering getting some PIAA type lights. Iím good mechanically but electrical is not strong suit. Anybody have success with a certain brand. There are some cheap ones out there for sure!
    Thanks in advance!
    Jeff 86 K 75
    KC Missouri
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Jeff,
    Welcome to the forum!
    I can only help with a couple of your questions.
    2. Yes, if your bike is an ‘86 US K75 it would be a C model. They sold K75Ss in the US in mid ‘86, but those were sold as ‘87 models. All the rest were C models. Cs came with either a simple headlight surround (like the K100 standard) or a body colored handlebar mounted “bikini” fairing that had a small windscreen and had the turnsignal arms molded into it.
    4. Can be a valuable addition. I recommend Kisan brand.
    https://kisantech.com/p115w.html
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Jeff,
    2. Yes, if your bike is an Ď86 US K75 it would be a C model. They sold K75Ss in the US in mid Ď86, but those were sold as Ď87 models. All the rest were C models.
    Or - The elusive "T" model.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Paul,
    You need to tell him what windscreen to use, since you've ridden similar bikes forever.
    If it was a T it wouldhave the engine guards (crash bars).
    Jeff,
    Your bike doesn't have the mounts for the engine guards does it?
    Mine, Hers, Spare
    Oct 2003
    "Big Bend" TX
    Paul,
    Jeff,
    The best windshield is the one BMW calls/called the International Shield. Ask a dealer.
    I donít think it does have the mounts for the crash bars
    Mine is a 86 "C" model. The mini fairing mounts onto a bracket that mounts to the upper fork tubes. For that fairing the only aftermarket windscreen available now is from Gustafsson in Florida.
    It does take some fitting (drill for attachment holes and heat gun to adjust it to a proper fit). This is a Gustafsson +6" and stock screen for comparison. Along with the factory screen with a Laminar Lip and just the Gustafsson.
    PeteG
    Dec 2009
    Woodacre, California
    Quote Originally Posted by jawjaboy View Post
    What a beauty!
  1. Replies: 14
    Last Post: 01-09-2016, 03:40 AM
  2. 7000 Miles what I think
    By JT_R1200RT in forum Hexheads/Camheads
    Last Post: 11-05-2009, 09:12 PM
  3. 12k service for '02 r1150r - NYC area
    By iamjhammons in forum Oilheads
    Last Post: 06-28-2006, 03:50 AM
  4. RT 12K service
    By IRONMAN in forum Oilheads
    Last Post: 03-10-2006, 06:14 PM
