Results 1 to 5 of 5
Thread: R-1100R PM question
    Rally Rat twins4life's Avatar
    Apr 2005
    Marble Falls, Texas
    R-1100R PM question
    Do the front wheel bearings need to be relubed ever? 32,500 miles.
    What about the steering head and the paralever ball joint?
    bmwmick
    Quote Originally Posted by twins4life
    NO and NO.
    To clarify this, you do NOT lubricate the front bearings, ever. They are sealed bearings. There 'used' to be a replacement schedule of 40,000 miles but this has been changed to an annual 'check' and replace if needed.
    Jim Bud
    Sedalia, CO
    I believe that the recommended replacement....
    for the front wheel bearing is 25K miles.....but I don't know anyone who does it...more likely 50k.....
    Jim Bud...
    Apr 2005
    Marble Falls, Texas
    Thanks!
    Port Angeles WA
    Just keep the pressure washer away from any bearings. Once water gets squirted by the seals, the party will soon be over.
    As long as the sealed ball bearings roll smoothly without any noises or freeplay, they don't need to be replaced.
    pmdave
