greywheels
Here are the details:
2004 r1150r
11500 mi. (not missing a digit)
afxid set at 5
r12 injectors
newly installed stick on left. went out last month
balance and throttles set using carbtune pro
Plugs are good, valves are within spec, new air filter
Hi All-
Have a strange issue I'm working on. I decided my bike was not running correct so I proved it. I had a few issues after a 1200mi trip in June. Bike began to sputter and pop. I noticed it was much hotter on the left side as well. Research and investigation proved the left stick coil was bad. Now replaced. I also replaced both injectors with the new r1200 model upgrade. Because of these changes I decided to check the balance and reset idle as the left BBS was about 1.5 turns out further on the left than the right.
I had it set proper this a.m. both at idle and around 3500rpm with idle established around 1100 (I did not hook up my 911). Carbtune showed a nice vacuum balance. This evening I went for a ride. Smooth, sharp throttle, well balanced, running strong. After it was good and warm, I noticed the idle was around 1500. When the throttle was blipped, it went down slower but steady to 1500rpm. I pulled over in the shade to turn back the BBS screws evenly, 1/4 turn each side. I kept turning and turning each side. The Idle dropped slightly and now the BBS are both completely seated tight and closed.
It still runs great!! What the heck?? It should be sputtering and chugging along in some ugly way, and certainly not acting like a hotrod, peeling out of corners, front end wanting to pick up. What is this witchcraft?
As for the throttle, there is 2-5mm (this is a guess, it's not tight) slack at handle and each side of throttle bodies. Both sides snap back to the stops. High idle switch/lever seems to be set fine, opens, closes with a noticeable difference and was needed to start up this evening.
This is a new bike to me, and my first boxer. Previously I had an '97 F650st. I like to wrench so am learning as I go. The bike runs well but mpg has always been low. Currently averaging 35 mpg over 30 fuel logs. Not good. Possibly the enrichened fuel from the afxid? Even so, that's pretty low even with a heavy right hand. Once I sort out the idle/BBS setting I can focus on mpg.
Any thought on this idle issue? Not sure where to start, but tomorrow, I will give it a good morning wake-up and come home to see if everything is balanced, think it through, do some more research.
Thanks for the help-
Eric
2004 r1150r
afxid set at 5
r12 injectors
Hi All-
Eric
