Results 16 to 24 of 24
Thread: F 750 GS Engine nature
    Aug 2018
    Dunlap, TN
    It has always been my understanding that the Rotax engines, like the F800 and F800st and GT motors had a 360 crank, where both pistons rose and fell together, like an old Triumph. Lots of potential for vibration with that design. The new China-supplied 750/850 has a 90 degree crank offset, which should make for a smoother engine than the earlier designs.
    Okanagan Valley, BC
    Quote Originally Posted by motormike View Post
    You have overlooked something important. The F800s are in fact smooth running because of a Rotax innovation - an ingenious counterbalancing pivoting connecting rod mounted on the crankshaft between the two piston rod journals. The connecting rod moves in the opposite direction of the two pistons. The first order forces are 100% compensated for and the secondary forces are 70% compensated for. The Rotax motors are in fact smoother that the Loncin engines.
    The 1993 Ducati Supermono incorporated a similar dummy rod counterbalancer system, which predates the Rotax design. Still pretty clever, though.
    -Live as fully as you can as long as you can-
    #13338 PGlaves's Avatar
    The principle of counter balancing rod/piston assemblies goes all the way back to steam engines at the turn of the 20th century.
    Okanagan Valley, BC
    From what I have read in various articles the Rotax counter-balancing scheme is less "power-sapping" than others.
    https://www.motorcyclistonline.com/p...-drawing-line/
    Aug 2018
    Dunlap, TN
    Interesting. I've been looking at the F800GT's but everything I've ever read screams about the handlebar vibrations from that engine. I would say it's the number one complaint, bar none. (is that a pun?) The tester of the F800 in this Visor Down video would disagree (1 min in and again at 2:08) with you: https://www.bing.com/videos/search?q...DFF6&FORM=VIRE
    Okanagan Valley, BC
    We have two F800s. Total of 240,000 kms. Vibration isn't objectionable and in fact I can't remember even thinking about it.
    Yeah but i believe Ducati was still the first to use the double connecting rod counterbalance system on the Supermono, although they only made a very few of those engines. I think it works better on a 90 degree angle (for reasons too detailed to discuss here), but the Rotax 804 can run pretty smooth, especially if the fueling is right. I readily admit i do not understand why fueling is a factor, but at least it was on my bike.
    https://www.cuoredesmo.com/the-histo...ermono-engine/
    I have never ridden an 800ST but did experience some high frequency, low amplitude “buzz” on the handlebars of a 700GS, but was able to eliminate most of it with some modification.
  1. 1972 750 engine question
    By kantuckid in forum Airheads
    Last Post: 05-19-2009, 12:03 AM
  2. Despite my fastidious nature . . .
    By flgoff in forum Campfire
    Last Post: 01-20-2008, 01:01 AM
  3. Trashing Out Mother Nature Needs Analysis
    By redclfco in forum Campfire
    Last Post: 04-20-2007, 04:38 PM
