Results 1 to 2 of 2
Thread: Hardwire radar detector and Gopro with usb
    It's time to hardwire my escort radar detector and my Gopro to my k1600. My initial plan is to hardwire a usb hub to the front of the bike and use the hub to power the two accessories. I can hardwire to my hexezcan or directly to the battery.
    My questions are:
    Can I wire the hub directly to the hexezcan and use it to power both the Escort and the Gopro?
    Would it be better to wire each one separately to the hexezcan with it's own usb adapter?
    Will the usb hubs transmit 12vdc if that is what they're connected to?
    Would a rj11-usb plug work to connect the escort detector to tye usb hub?
    The thought behind the hub is I'm sure the connectors will eventually fail on the units, and replacing the patch cord to the hub will be much easier than running a new wire.
    Thanks, James
    To answer your questions:
    Yes you can. The hexezcan looks like a power distibution hub, so there's no reason why you couldn't.
    I think independent ciruits would be a little better, but it's not critical.
    No. USB is nominally 5v unless it's a quickcharge protocol that uses 9v.
    Not sure what you are asking here. Are you looking for a cable with an rj-11 plug on one end and a USB terminal on the other? Never seen that, and wouldn't make any sense to me.
  1. Replies: 10
    Last Post: 07-18-2021, 01:26 PM
  2. Replies: 7
    Last Post: 10-24-2016, 03:43 AM
  3. R1200GS Radar Detector Hardwire Success/How To
    By coloktmGS in forum Oilheads
    Last Post: 07-27-2005, 08:48 PM
  4. Radar Detector and Back Rest
    By Michael1515 in forum Flying Brick K-bikes
    Last Post: 03-20-2005, 03:32 PM
