Results 1 to 5 of 5
Thread: 2000 r1100rt fuel line placement.
    I got a r1100rt not running. I want to know does the supple fuel line goes to the top or bottom fitting? Thanks in advance.
    1997 Honda Valkyrie & 2002 F650GS
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Does this help?
    Nibley, UT USA
    Normal practice on fuel lines with quick-disconnects is to have one male and one female end coming from the tank and the same setup on the lines running to/from the fuel rail. That way there’s never a doubt about which line goes where as they will only fit one way.
    Best,
    DeVern
    DGerber
    Does high pressure line go to top or bottom??
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    Supply is the bottom hose on the fuel distributor.
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
  1. 1996 R1100RT Fuel Distribution Line Repair
    By oldcarman in forum Oilheads
    Last Post: 11-29-2019, 01:11 AM
  2. Fuel drain line placement - Help 2000 r1100rs
    By mhallman in forum Oilheads
    Last Post: 04-09-2018, 05:47 PM
  3. R1100RT another Fuel line disconnect question
    By Dadrider in forum Oilheads
    Last Post: 04-22-2012, 09:19 AM
  4. Fuel Line and vac line question
    By grumpyone in forum Airheads
    Last Post: 08-11-2008, 07:34 PM
  5. R1100RT Fuel filter / line issue
    By beemernow in forum Oilheads
    Last Post: 09-21-2007, 01:27 PM
