Results 1 to 4 of 4
Thread: Missing Roundel / Emblem 2012 R1200RT
    May 2014
    Sherwood, AR
    Just returned from the National rally and noticed that I've lost yet another roundel from the side of my 2012 R1200RT.
    The assembly is two pieces consisting of a base that mounts to the body panel and a sticker that mounts to the base.
    In my experience, the stickers will depart the bike while the base remains intact. I've seen quite a few bikes over the years missing these roundel stickers so I'm hoping someone has sourced just the sticker instead of having to buy the entire assembly at $60+ each.
    The assembly part number is 51147721222. The roundel is 70mm. There is a slight rise in the center of the base so a completely flat sticker won't work.
    Thanks in advance to any help you may be able to provide. Much appreciated!
    Nibley, UT USA
    An easy and cost-effective solution might be to just remove the base, using floss or fishing line, and replace the roundel with one of these:
    https://toastertan.com/product/bmw-roundel/
    You could do a permanent solution on both sides of the bike for less than the price of one OEM replacement
    Best,
    DeVern
    DGerber
    Registered User TEDZEMLICKA's Avatar
    Aug 2006
    Southeast Iowa
    Mine went AWOL during the rally too. Must have been a popular souvenir for someone
    May 2014
    Sherwood, AR
    Quote Originally Posted by GTRider View Post
    Best,
    DeVern
    Thanks for the info sir.....much appreciated!
  1. 2009 K1300GT, missing BMW roundel
    By swentac74 in forum Wedge K-bikes
    Last Post: 10-28-2019, 03:59 PM
  2. BMW Gas Tank Emblem Removal?
    By JOHNP in forum Airheads
    Last Post: 05-23-2007, 06:28 PM
  3. Got an extra emblem?
    By BILL6FT6 in forum Airheads
    Last Post: 09-07-2006, 12:51 PM
  4. R90 engine emblem glue?
    By MARTYH in forum Airheads
    Last Post: 08-27-2005, 05:03 PM
  5. Need Engine Emblem
    By johnltaz in forum Airheads
    Last Post: 06-13-2003, 02:26 AM
