The photo shows “L” bar in approximate position however, the hole drilled for hand grip is way off. It should be just to left of wonder wheel (under edge of rubber grid). The bar marked “R” has bar at correct distance to match the left side grip screw. What’s going on here? Anyone mounted these and have same out of whack hole positions? Or are the bars mis stamped?
