Results 1 to 6 of 6
Thread: lower pully torque value
    Simple question - torque spec on the crank pulley (bottom front bolt on the crank of the pulley that drive the alternator on a belt). Could use metric spec ( 75 nM for 10.9 ). (with blue locktight - reduce 10%?)
    BMW R1100RT 2000
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    My book says 50 nM ( = 36.87 lb-ft) in two places; screen shots attached.
    Doc1.doc
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    Quote Originally Posted by Pauls1150 View Post
    Doc1.doc
    About right, no manual, rule of thumb puts me at 35 ft/lbs..
    Don't reduce for blue loctite and if you use red loctite, sell the bike if you have to take it apart again.
    I might have a concern that oxidation will compromise that torque value.
    Best to make sure washers, pulley face, internal/external threads are clean.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Registered User jrogers's Avatar
    Mar 2021
    Nor-Cal
    Dry or wet, always a question.
    02 R1150R ABS, 04 R1150R, 04 R1100S BCR, 05 R1100S BCR, 16 S1000XR
    Neglected Bike Adopter
    Jun 2021
    Middle Tennessee
    Quote Originally Posted by dieselyoda View Post
    There is but one way to effectively break red Loctite: exposure it to a temperature over 500 degrees Fahrenheit. Theoretically you could get that bolt to that temperature, but I would not want to be in that situation if at all possible.
    Blue is the choice for almost every automotive application.
    Also, relevant to this thread and to the problem of oxidation, I did a minor mod to my own machine regarding this bolt. I don't understand why BMW gave it a 16mm hex head when there's no tool in the tool kit that lets you touch that fastener; standard M10 bolts have a 17mm head and there's a 17mm wrench in the tool kit for the rear wheel lugs.
    I bought a pair new replacement M10 bolts of the same length (I believe it's 35mm), with a 17mm head, from my local auto parts store for about $4. The original definitely had a bit of corrosion on it so the new yellow zinc oxide one was less crusty. Reused the original washer.
    Now, if I have a Hall sensor issue out on the road or my alternator belt pops and damages the pulley, I'd be able to remove it with the on-bike tool kit. The rear wheel lug wrench is definitely capable of getting it up to the required 36 pound-feet of torque.
    Owner of the saddest 1997 R850R you ever did see.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Spec from BMW CD is 50nm, no oiling, no loctite.
    Lock the crank at tdc with a 5/16" pin in the hole above the starter.
    Don't attempt to lock the rear brake in 6th - not solid enough to get a reliable torque reading.
    Ufda happens..........
  1. torque value for rear frame
    By KARSTEN in forum Oilheads
    Last Post: 01-23-2011, 08:08 PM
  2. Torque Value for 09 RT
    By MCDONELL in forum Hexheads/Camheads
    Last Post: 06-09-2009, 12:16 AM
  3. Anyone Know the Torque Value?
    By MurphyPeoples in forum Airheads
    Last Post: 08-08-2007, 12:28 PM
  4. Re-installing Brake Rotors, Torque Value?
    By milo in forum Flying Brick K-bikes
    Last Post: 04-10-2006, 01:51 PM
  5. Caliper torque value
    By DcnDog in forum Flying Brick K-bikes
    Last Post: 04-19-2005, 02:04 AM
