Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: 1994 R1100RSL. Do Throttle-body cleaners with Acetone also dissolve the TPS insides?
  1. #16
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    The thin white line (small gap) between the throttle body bore and the throttle plate is the bulk of the air required at idle. The bleed screws just fine tune that to obtain the correct idle speed and balance. The actual position of the throttle plates is set with a very sensitive airflow meter at the factory - thus the blue paint on the adjusting screw.
  2. #17
    I'll Be Back! beeminator's Avatar
    Jan 2008
    La Jolla, California
    Try Seafoam for cleaning. It highly regarded in automotive circles.
    2002 - R1150R Atlanta Blue
    1982 - Porsche 928 - Gold
  3. #18
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    David327 (Chevy?) - if further questions are related to what's going on here, stay in this thread; if they're a completely different topic, start a new thread.
    I sometimes have access to other folks' "junk", so I was able to make this handy little gizmo for TPS measurements:
    Pin 1 - the white wire with a red runner, topmost in the photo and rearmost on the bike - is the TPS measurement point; use the brown wire attached to the throttle body as your ground/return.
  4. #19
    Yes, that pictured patch cord is ideal.
    Yes, that pictured patch cord is ideal. Beemer Boneyard says he hasn't any suitable connectors for me to solder together as you pictured.
    I'm considering Mr. BewareBoy's idea of using a sliver of lamp cord wire in the TPS connector, as above.
    Or Mick McKinnon's post,
    k11og.org/forum/viewtopic.php?t=2110&postdays=0&postorder=asc&start=0.
    Mr. McKinnon says all R1100 bikes with 2.2 Motronics can use the diagnostic connector and an LED...
    I am delighted by y'all's ideas: the feeling of expert teamwork, the empowerment.
    And I'm delighted how my posted question brought machine-generated archived thread suggestions I couldn't find manually when I searched. Advertising automatically spams me related products, now that automation worked in my benefit!
  5. #20
    Feb 2005
    Trinity, NC
    Quote Originally Posted by davidanderson327 View Post
    I just want to emphasize that the TPS Adjustment Test via the diagnostic connector is just a pass/fail test. It shows that the TPS at idle is in the acceptable range, it doesn't show the voltage.
    That connector pictured is a neat piece of work. I take a single wire from a four-wire telephone cord, strip off the insulation at each end and slip one twisted end into the TPS pin 1 slot and close the connector again. The wire is thin enough that it will conform to the closed connection and still allow it to close. I then attach a voltmeter to the end of the wire sticking out from the TPS connector and measure the voltage on pin 1. At idle, I shoot for 380-385 mv.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
  1. Replies: 4
    Last Post: 04-12-2019, 11:25 PM
  2. Replies: 33
    Last Post: 04-30-2016, 02:18 PM
  3. Replies: 13
    Last Post: 09-06-2012, 04:21 AM
  4. Acetone and ATF Don't want to mix
    By jconway607 in forum Oilheads
    Last Post: 01-16-2012, 01:20 PM
  5. Acetone as a fuel mileage enhancer??
    By screwtop in forum Campfire
    Last Post: 06-09-2008, 03:12 PM
