I always thought moving to “shim & bucket” style valves was a way to reduce weight and rotating mass in the engines…..especially those with higher redlines.
Mod Squad
2009 F800GS 1994 TW200
True (it's reciprocating mass, I think), along with less wear overall (when the right metals are used and properly hardened, of course!).
My Camry has solids.
Not only can hydraulic lifters "pump up" at higher revs, causing valve float, they can also collapse.
Bad boogie either way.
My 82 Honda Sabre was time consuming to adjust the rear cylinders. Because of a previous experience with a dealer valve adjust that was billed and not done, I marked the valve covers on this one. Yep, no adjusting of the rear bank. So the tech, in doing it over, left them nice and loose. I got Honda involved. Did not help. Small claims court date was ignored, summary judgment not paid. Dealer went out of business. Ended up getting less than $20 from bankruptcy court, with the film and picture developing and printing, I made nothing.. Lawyers made out well. There are dealers that have soiled the reputation of all dealers.
Rod
Thanks for the feedback so far everyone. The few times I've posted a question here, there's been nothing but informative and interesting responses. One of the main reasons I've been a member for 13 years is the forum.
One fact that made me think of the original question is that BMW (the car division) itself makes a 2.0 liter, 4 cyl, 322hp engine; MB has a 2.0l, 4cyl, 416hp; Volvo has one with the same configuration with 415hp. These are all high revving engines that do not require valve adjustments as far as I could find out. So why not a 1.6liter, four or six cyl, 140-160hp no-valve adjustment engine? Also, it's not only the cost--as one of the guys has said, you buy an expensive bike you should be able to pay for its upkeep, I get it--but having it done correctly. What bothers me is paying for something and not receiving it.
I'd guess it's a combination of size and weight. You can deal with a lot of both in a car and you want as little of both on a motorcycle. Also, in my experience, shimmed valves almost never go out of spec after the break-in period and I've never have more than one shim replaced at the first servicing.
BTW, for some years, BMW car motors have used their variable valve mechanisms instead of throttle bodies to control airflow into the motor. It's a slick piece of technology and is great for both efficiency and power, but its awfully large for a motorcycle. The is a slightly old explanation:
https://www.facebook.com/Engineering...3512885391727/
And if BMW follows those leads, dealing with a smaller and smaller segment of well-heeled buyers who simply don’t care about maintenance costs and service info availability, then I’d expect that down the road we’d see BMW dealers becoming as scarce as Lambo and Bugatti dealers. BMW motorcycles, too, for that matter.
Best,
DeVern
DGerber
I imagine some of this can be traced back to engineering design decisions being made by those that don't ride or don't ride very much. Absolutely decisions being made my those that don't work on their own bikes. One of the questions for magazine interviews with BMW executives should be "what types bike maintenance have you performed in the past on what model motorcycle?". Probably not as much a BMW thing as much as a sign of the times.
Wayne Koppa
Grayling, MI
#71,449
I was thinking that after the design and engineering, the designers and engineers should be required to work on their creations.
Mod Squad
To get to the powered outlets in the cowl of the 310GS to hook up accessories there are 34 screws. Only 34. They could have engineered easy removal of the headlight from the front but didn't from what I can figure out. Some have said you can get the headlight out from the front but it don't seem to be possible or practical to me. Only 34
Wayne Koppa
Grayling, MI
#71,449
Mod Squad
Jeff in W.C.
2018 R1200 GS
