I have given up trying to understand where Garmin is going with route creation applications, but it appears that they are slowly transitioning to a browser-based application called Explore, and away from Basecamp.
There is also an Explore App for your phone.
Below is a flowchart I drew after buying my ZumoXT and not being able to figure out what was going on. It’s still incomplete, I gave up and now use the Zumo pretty much as a moving map, or to autoroute to some place I need to get to.
There are just too many apps, too much confusion around what’s in the cloud or on the device and where… I just use Basecamp on my Mac and do things the old-fashioned way.
It’s a major bummer that the Zumo will not display saved waypoints on the screen unless you choose one to navigate to.
Thanks been on basecamp for an hour and as simple as it seems I can't just create a short route. Will need to find another tutorial I guess. It did show my past ride track when plugged into the GPS. Easier I think to use my finger on the GPS map or choose a location there.
I have been able to select POI's from GPS factory and get those transferred to the GPS.
Interesting but after logging on the explore Garmin site it seems it doesn't work with a Nav VI. Out of a short list of gps devices, only the zumo XT would work.
Basecamp is great for planning complex routes and transferring to your Garmin or Navigator V/VI gps. Once you get the hang of it, it is simple to use.
Try the tutorials at this link.
https://www.newenglandriders.org/learn-basecamp/
