Recently acquired a 2003 F650cs ABS that has been sitting for some time.It has no rear brakes at all ,the pedal goes to the floor ,so to speak.The front brake seems to be working just fine.The reservoir is full of fluid. I tried to bleed it, nothing at all came out of the bleeder valve.I’m not real familiar with the ABS system.Is there anything that I need to check before tearing into the master cylinder?
