Hi everyone. Looking for a lift or stand or whatever else you have tried for an F800gs to perform chain, wheel/tire and other maintenance
Thank you
A centerstand will do what you need. Does your bike come equipped with one?
I am past rolling around on the ground, so I bought a Harbor Freight lift about ten years ago and it's been one of my most used and useful tools. It seemed like an extravagance at the time, but at $300, it's turned out to be a smoking deal. Even at $400, it's a terrific deal.
Pretty much my thoughts. I have done most with just the center stand. It may take a bit of care using the center stand on the steel lift due to the metal to metal slide possibility but gets you off the ground.
Easy for a competent welder to modify a standard height center stand. SWMOTECH and Happy Trails sell stands.
SWMOTECH sells short centerstands for the factory lowered bikes. Easy bolt on.
You did mention in your first post that you couldn't mount a centre stand, I guess everyone else who replied didn't bother to read that far.
You could also pull the rear tire onto a block to make putting it onto the center stand easy.
Sent from my SM-N970U1 using Tapatalk
