ken e
Ken
Pried off the Roundel badge on the upper fork bridge and found water damage.
The culprit seems to be the plastic O-ring holder/plug that the roundel is adhered to has a vent molded in and is pointing UP letting rain and wash water straight into the cavity. Why did they do that???
I cleaned every thing up, re-greased bearing and positioned the vent DOWN.
Also drilled a small drain hole thru the fork bridge just above the bearing retaining ring that is angled down and back.
Current millage is 114k and all is good now.
