Hi, I'm midway through resealing the heads on my '74 R75/6. Got the right cylinder reassembled and noticed an odd noise while I was rotating the engine to set the valves. Hopefully you can see/hear it in this video. Essentially, it seems there is a click when the intake valve begins to open. My hunch is it is related to the valve spring/assembly. All of the head bolts are torqued, and the rocker arms are adjusted to spec. Gave things a good cleaning before reassembly, so I'm wondering if the valve assembly is just a little dry? Thanks in advance for your help!
