Brake and rotor question
88bmwjeff
SF Bay Area
This has been bugging me for about a week. I'm having my rims powder coated. While it was my intent to properly mark/set aside each rotor so the right one would go back on the right and the left on the left. That way the pad and the rotors would be matched. Well, you can guess where I'm going with this now. In taking the rotors off, I got them mixed up. I know I should have marked them somehow before taking them, but I was 100% sure before I started I could keep them separate. Well, they got mixed up. Now, I'm left with the following options
put them on and don't worry
get new pads
Is there another option?
Put them on and assume you need to break them in like if they were new. It will at worst take a little time for them to mate with the rotors.
And you can't tell from close examination from scratches/marks in the surface as the begin at the holes and spread out which way the rotors were spinning??
I went out to the garage and inspected the rotors and I can seed that one side of the hole does have scratches and marks. Thanks. Just to be clear. Am I correct in my assumption that the scratches/marks would be on the trailing edge of the hole not at the leading edge?
That's what I would assume. And I'd still err on the side of caution and do as others have suggested...treat it like you need to bed the pads in and don't heavily depend on all the brakes all the time at first.
