Results 1 to 3 of 3
Thread: 1985 K100RS fork tube pitting?
    Jan 2020
    Calgary, Alberta, Canada
    These marks you see in the black circle aren't scratches. They appear to be tiny pits about 40mm (to the lowest one) from the top of the slider. Corrosion? I can easily snag a tiny, flat-bladed screw driver on them which tells me it will scratch my stanchion and probably did, although I have dressed the stanchion with 600 grit emery cloth. I have tried removing them with 600 grit but it appears it's going to be more than a few passes with sandpaper to do this.
    I believe they are high enough in the slider so that suspension travel with scratch the stanchion and that area will then pass by the fork seal, possibly/probably nicking the seal and causing it to leak.
    I have no idea if they were there last winter when I upgraded my front forks with Race Tech emulators and springs but they could have easily been missed.
    What do you guys think I should do-sand some more and try and get them out or look for a set of used fork tubes/stanchions? The latter wouldn't be hard to locate at all.
    A “pit” should not scratch the fork tube, as it is further away from the fork tube than the rest of the inner wall of the slider.
    A “burr” on the other hand WILL scratch the slider because it protrudes further in towards the fork tube.
    I would think that just enough light sanding to soften any sharp edges should be ok. Take a small straight edge and insure nothing sticks up from the wall of the slider.
    Jan 2020
    Thanks, Lee, I’ll proceed along those lines.
  1. 1985 K100RS scraped fork tube.
    By mcmlcccvrs in forum Flying Brick K-bikes
    Last Post: 11-29-2020, 07:43 PM
  2. R75/5 Leaking fork tube at fork brace
    By JB1982RT in forum Airheads
    Last Post: 05-11-2014, 10:58 AM
  3. Fork Tube Replacement
    By wecm31 in forum Airheads
    Last Post: 08-26-2011, 01:12 PM
  4. Replacing Fork Tube
    Last Post: 06-11-2011, 05:50 AM
  5. Fork Tube Rubber Boot install (K100RS)
    By Sandhog in forum Flying Brick K-bikes
    Last Post: 07-02-2009, 03:17 PM
