1991 K100RS Fuel Pump
Has anyone found a substitute fuel pump that fits a 1991 K100rs 16 Valve? I know about the NAPA P74095. Has anyone done this?
DC
On the Road
Ford Mustang Pump
I put a fuel pump from a Ford Mustang in a 1985 K100 about six months ago. I think the pump was the same number you mentioned but I would have to check to make sure. The bike runs like it should with the Napa pump and is still working today.
Installation:
- the Napa pump has a smaller diameter than the stock bmw pump so it needs to be spaced with something to fit properly in fuel pump holder. I just wrapped the rubber hose included with the pump around the pump which seemed to make for a pretty tight fit.
Other than that installation was pretty easy.
hope that helps,
ben
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
