roninbuffalo
Member
I got a set of nikasil jugs I want to to put them on a 77 r100 short block is there anything needed to be done before I do this?
Later 80/90’s cylinders have a step in the base that has to be machined off to fit a /7 block.
Snowbum writes about this in red font about 1/3 the way down this page:
https://bmwmotorcycletech.info/cylinders.htm
Assume you have the corresponding pistons.
Pistons? I thought the issue would be rings.
