Results 1 to 15 of 15
Thread: Where can I get an inexpensive fuel filter ?
    I was looking over my 1991 K75 RT today and after chaining oil, decided I should see about getting a fuel filter . The local BMW bike shop here in Calgary shows one for $56.95 . it looks just like ones I use on my old carburetored vehicles . What does everyone on here use ?
    Your carburated fuel filter is rated for about 10 psi and could rupture on a fuel injected engine. Fuel injection filters are rated for over 100psi. Your bike runs on about 40 psi, but your pump puts out over 100 psi. If anything goes momentarily wrong, your filter will be subjected to 100 psi. and burst.
    Properly rated less expensive filters can be purchased from euromotoelectrics.com or beemerboneyard.com.
    RK Ryder
    London, Ontario
    I’ve been using NAPA Gold 3032 fuel filters in my K100 for years without any incidents. Although the price has increased over the years, they are much less than the price you stated.
    Paul F. Ruffell
    Knights of the Roundel #333
    Beemerboneyard.com
    Be aware that that filter has a burst pressure of 60 psi. Any problem with the fuel pressure regulator or anything done during diagnosis of the fuel pressure that will bypass the regulator will exceed that pressure.A kink in the pressure return hose could also cause the filter to burst.
    It has adequate burst strength to handle normal operation.
    The Napa 3032 filter filters down to 20 micron. Factory specs are 10 micron.
    The Mahle KL145 meets factory specs. Rated for 80psi and 10 micron. About $20 on Amazon This is the filter
    Euromotoelectrics sells, I believe.
    Jun 2009
    Rochester, MN
    Quote Originally Posted by Visian View Post
    Beemerboneyard.com
    and they support the MOA! (MOA members also get a discount... )
    Dances With Sheep GREGFEELER's Avatar
    Boise, ID
    Quote Originally Posted by drneo66 View Post
    I would say to buy from the independent suppliers mentioned on this thread first, but you can get the Makle KL 145 from Amazon for $20.00"
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Greg Feeler
    Ambassador & 2022 BMW MOA Rally Co-Chair
    1972 R75/5, 1990 K75, 1990 K1, 1992 K75S, 2003 K1200RS
    Apr 2009
    Huntersville N.C.
    You are correct Lee, When I worked for Penske Racing Wix Filters was one of our sponsors. Wix filters makes the NAPA filters. I asked the Wix rep one day what he thought about people using the 3032 filter on fuel injected engines. He was surprised people would do that. It is a crimped filter designed for low pressure applications with a carburetor. I look at it this way I change my fuel filter & the two hoses every four years regardless of the miles. That works out to about $30 a year or $2.50 a month. I change the hoses every four years because of the Ethanol fuel.
    Dave Selvig
    2009 Red 1300GT
    2004 Black 1200LT
    2000 Canyon Red 1200LT
    Nibley, UT USA
    The correct fuel filters are $17.95 from Beemer Boneyard, and for MOA members the code in the BB ad found in every issue of the ON magazine will knock $1.80 off that.
    https://www.beemerboneyard.com/16142325859.html
    Best,
    DeVern
    DGerber
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Saddleman Dave - I believe that Wix rep was incorrect; while the 33032 allows particles 10 microns larger than a factory filter (20 microns = 0.00079 inch), it is indeed injection-rated, with a 60-pound burst pressure. It is used as a universal replacement for many cars and trucks.
    fuelfilter for K75
    Thanks for all the great advise . I just odered 2 Makle 145 filters from amazon .ca $22 canadian each .
    Aug 2018
    Fargo, ND
    Burst pressure is 60 PSI, not working pressure. Working pressure should be less that half, perhaps a third of burst. If your fuel injection pressure is 20-30 PSI it is probably ok, but most fuel injection pressures I see run in the 50-60 PSI, over what that filter is rated for.
    I will admit I don't know what pressure the fuel injection pressure is on the OP's ride and unless he knows I would avoid the Wix 33032.
    https://www.wixfilters.com/Lookup/Pa...spx?Part=56820
    From the only real Fargo, ND!
    K75 pumps put out near 100psi. It is regulated down to 38psi. If the return hose from the regulator gets kinked (very easy to do when reinstalling the tank or if you do not use the $40 molded hose for the return hose) the pressure can skyrocket, well above the operating pressure.
    Aug 2018
    Fargo, ND
    Even at 38 PSI and the filter having a burst at 60 PSI I wouldn't be comfortable using that filter. I would be looking for one with a burst pressure around 100 PSI.
    Wow, I didn't know the pressure is that high... Thanks!
  1. '87 K75s Fuel Pump Filter Gauge Breather Hose Routing - Fuel Pump
    By kentuvman in forum Flying Brick K-bikes
    Last Post: 10-26-2021, 02:22 AM
  2. Inexpensive R1150 fuel disconnects
    By GSAddict in forum Oilheads
    Last Post: 08-21-2010, 05:02 PM
  3. fuel filter
    By f14rio in forum Airheads
    Last Post: 05-04-2010, 11:01 PM
  4. Fuel filter?
    By kbasa in forum Hexheads/Camheads
    Last Post: 07-25-2009, 03:44 PM
  5. new fuel filter now no run
    By smilinrider in forum Flying Brick K-bikes
    Last Post: 10-12-2007, 03:02 PM
