Results 16 to 30 of 44
Thread: 1997 R850R Start-up Cam Chain Noise w/Upgraded Tensioner
    #13338 PGlaves's Avatar
    Quote Originally Posted by senseamidmadness View Post
    The Castrol I've already purchased exceeds these standards by meeting API SN, and that's good enough for me.
    And therein lies the rub. Just because SJ or SN oil is a later rating does not mean it meets all of the criteria for earlier oils, even if the API pretends it does.
    Quoted here is the BMW position stated in a Service Bulletin when API claimed that SJ oil was as good as SH oil:
    Bulletin Date: 11/25/98 Main Group: 11 For USA Only
    Bulletin #2855 Engine
    BMW Motorcycles
    Service Bulletin
    Service Bulletin: SJ Engine Oil - Not Approved
    Specification:
    BMW provides specific recommendations for fuel and lubricants in the
    Service and Technical Booklet for each model motorcycle, or in the
    Riders Manual on older model motorcycles. These recommendations are based
    on specific knowledge of the engine requirements and thorough endurance
    testing.
    Recommendation:
    The current recommendation is as follows:
    Brand-name HD oil, API classification SF, SG or SH; CD or CE suffixes are
    permissible; alternatively, brand-name HD oil, CCMC classification G4 or
    G5; suffix PD2 is permissible.
    Not Approved:
    The API specification SJ is not approved for use in any BMW motorcycle.
    This latest API classification does not guaranty the required levels of
    wear protective additives such as Calcium, Magnesium, Zinc, etc. as with
    most prior API specifications.
    Customer Interaction:
    We suggest that you council with your customers regarding the oils being
    used in their motorcycle. Most oils found in commercial discount and
    automotive supply stores are now API SJ classification, which means that
    they should not be used.
    Very truly yours,
    [signed] [signed]
    Frank Stevens Pat Raymond
    After Sales Manager Service Organization
    Motorcycle- Group
    Neglected Bike Adopter
    Jun 2021
    Middle Tennessee
    If what you're implying by that bulletin is completely accurate, then Spectro 4 and Spectro Golden 4 oils (which are now API SL certified per Spectro's website) aren't safe for use in Oilheads...and isn't that the OEM oil that BMW sold for our bikes in their own rebranded bottles?
    API independently lab tests all their newer oils to meet or exceed the exact same anti-wear requirements as the old ones. SN's requirements even explicitly feature a flat tappet wear test to disprove the myth of the superiority of ZDDP. Unless they're straight-up lying about their lab results, that is good enough for me and my bike.
    Owner of the saddest 1997 R850R you ever did see.
    Left Coast Rider
    That is good enough for me and my bike.
    Considering Mr. Glaves' extensive first hand experience, and his reputation in the BMW world, his advice should be "good enough" for you and your bike.
    I must comment that, for someone who has come here seeking advice on how to fix an issue, you seem argumentative when given that advice.
    Jun 2021
    Middle Tennessee
    This is because I didn't ask for oil recommendations and did NOT want to start an oil thread. That choice has already been made and I'm switching to the correct viscosity. I just wanted to know what was causing my cam chain rattle.
    I didn't write that bulletin. I am simply providing on this forum what BMW says about oil for your bike.
    The most likely cause of your chain rattle is the use of an out-of-spec oil, which means that a discussion of oil specifications is unavoidable.
    That said, it is your bike and you can do with it what you wish, whether that meets BMW specifications or not. Your bike; your choice; your risk.
    Mansfield,MA
    In the old days of "side of the road" car dealers, didn't they quite things with really thick oil or sawdust?
    Mod Squad
    2009 F800GS 1994 TW200
    There have been documented examples of sawdust, rice, and corn starch found in automotive final drives.
    Left Coast Rider
    In the old days of "side of the road" car dealers, didn't they quiet things with....sawdust?
    What kind of person wood do that?
    Mar 2013
    Winnipeg, MB, Canada
    Bananas work the best. T'was a thing back in the day to keep a diff together enough to make it someone else's issue.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
  11. #26
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Belmont Motors on Kingsway in Vancouver was famous for sawdust in transmissions up here in British Columbia in the '70s.
    Ufda happens..........
  12. #27
    Jun 2021
    Middle Tennessee
    Following up for the sake of anybody else who has this issue down the road:
    After my oil change to 20w-50, the rattling cam chain noise on startup is gone. My particular bike seems to be overall happier running that viscosity.
  13. #28
    I had an R1150R - almost the same engine except displacement. In 189,000 miles I always used 20W50 SG or SH rated oil. If it was cold enough to need a thinner oil I didn't ride it.
    ADDED: I went to the shop and looked up the viscosity specifications. 20W50 is specified for ambient temperatures from 14F (-10C) and higher. 10W40 is specified for ambient temperatures from 4F (-20C) to 68F (20C). 15W40 is specified for ambient temperatures of 5F (-15C) up to 86F (30C).
  14. #29
    Jun 2021
    Middle Tennessee
    Further follow-up: the noise has returned, but I'm not that concerned about it.
    I don't have a garage so my bike has to live outside, and it's been fairly cold lately. The noise is definitely worse when the engine is quite cold, under 50 degrees F, though it still does happen very briefly on hot restarts.
    The rattling noise only happens on start-up in all cases, and it goes away as soon as oil pressure builds. Just a blip of throttle (2000 rpm), or less than a second running with the fast-idle lever fully pulled, and it disappears.
    I figure it's an old bike and it's just going to make some noises here and there. A tiny amount of cam chain rattle when starting shouldn't snap the guide rail, right?
    Maybe I just need to charge my battery. It's been cranking a bit slow on start-up the last couple weeks now that the temperature's really gone down.
  15. #30
    Bluenoser
    Lethbridge Alberta
    These generation bikes also had right side throttle plate rattle as they put on the miles. Often got confused with valve noises. Also the clutch can make some funny noises at idle. Try to isolate where the rattle is actually coming from, use a long screwdriver or auto stethoscope to help.
    From my R1100 days, the big difference between the old and new tensioner was that the new one didn't bleed down like the old one did. Oil threads tend to head to the basement pretty fast.
    1986 K100RT
  1. 1997 BMW R850R Sudden No Start - Not Just the Hall Sensor!
    By senseamidmadness in forum Oilheads
    Last Post: 07-18-2021, 01:41 AM
  2. Cam Chain Tensioner
    By hottech in forum Oilheads
    Last Post: 11-01-2012, 05:17 AM
  3. Help Cam Chain Tensioner
    By EMSimon in forum Oilheads
    Last Post: 05-05-2009, 07:36 PM
  4. Cam chain tensioner
    By jammess in forum Oilheads
    Last Post: 05-24-2007, 04:05 AM
  5. Chain Tensioner
    By burnszilla in forum Flying Brick K-bikes
    Last Post: 02-18-2005, 07:28 PM
