Results 1 to 12 of 12
Thread: Hand Clutch Switch 2014 R1200RT
    Hey all,
    I'm having issues with my clutch lever switch not allowing me to start in gear. If anyone has replaced one for my year 2014 R1200RT (which I'm sure someone has) do you have the part number and who did you purchase it from.
    Thanks in advance,
    Robert
    Registered User easy's Avatar
    Feb 2005
    Texas Hill Country
    Read post #6. That might help.
    https://forums.bmwmoa.org/showthread...arting-problem
    And, welcome to the Forum.
    E.
    Quote Originally Posted by easy View Post
    And welcome to the Forum.
    E.
    Thanks, I saw that but no mention of part # or where purchased. I know my switch is bad.
    Lanark County near Ottawa ON
    It is likely this one.
    Sep 2009
    Cherry Hill, NJ
    You're probably looking for #9 in this diagram from the MAX BMW parts fiche:
    There are two versions of this switch and this part of the diagram only shows the version which is used in RTs with Shift Assistant Pro and Cruise Control. BMW Part #32 72 8 537 608 is for bikes without cruise control. It has a price which is eight dollars less. I have the same issue. The microswitch piece is secured in place by a tiny self-tapping screw which looks to me as either a Torx or Allen head.
    Here's how it's shown on the Euro MotoElectrics website:
    John Gamel - BMW MOA Consumer Liaison 2018-Present
    2015 Ebony Metallic R1200RT
    MOA #153274
    "We have met the enemy and he is us." Pogo-via Walt Kelly
    Mehrten
    Nov 2004
    Arizona, USA
    Before you spring for a new switch, make sure the one in place hasn't moved slightly causing a problem.
    It is a common happening with the older K bikes.
    Sep 2006
    CENTEX USA
    The screw holding switch is a 1.5mm hex. Switch doesn’t rotate much but a little is all needed.
    Be careful as there is a small and I mean small button spacer the screw tightens against if you remove switch. You will never find it on a shop floor!
    Steve Henson-Mod Team and past prez SABMWRA
    Sep 2009
    Cherry Hill, NJ
    As noted earlier, I had the problem of not being able to start the engine except when the transmission was in Neutral. I just took the two microswitch piece out of the clutch lever. It was dirty (39K miles on my RT). I cleaned it up and here's the result after the cleaning:
    I carefully returned it to its place in the lever housing, inserted the tiny screw using a T8 Torx driver, repositioned everything, and gave it a try. It worked immediately! Nice. We'll see how long this fix lasts.
    Thanks to Omega Man for his wisdom and experience regarding micro-switches.
    MOA #153274
    Quote Originally Posted by RadioFlyer View Post
    Thank you for the information!
    Quote Originally Posted by ExGMan View Post
    Thanks for your response I'll give it little electronic cleaner.
    Sep 2009
    Cherry Hill, NJ
    Update on My Clutch Microswitch Experience
    Well, fast forward a few days. I had taken the switch out of the housing at the clutch, found that it was very dirty, and used various physical and chemical methods to clean it up. That minor bit of work got it going again. But, after a couple of days of riding around NJ and PA, it stopped functioning.
    I had already scheduled a service at Quaker City BMW in PA. I told them of my difficulty, and as soon as they replaced my clutch microswitches they were working again as intended. Here is a photo of the part which they took out of my 2015 RT showing the two switches in one unit:
    FWIW, this piece failed after about 6.5 years of usage over 40,000 miles. I probably use the clutch a lot, living in intensely-developed MA and now NJ.
    Omega Man has had a lot of experience in microswitches in the work that he does. He said they all have a life, and sometimes can be revived for a while after failure. Once again, Gary was right.
    MOA #153274
    Thanks for the heads up!
  1. 2011 R1200RT Left Hand Combination Switch Failure; Options?
    By banzaibob in forum Hexheads/Camheads
    Last Post: 10-06-2014, 03:39 AM
  2. Failing Clutch Switch-2010 R1200RT
    By Velvet Glove in forum Hexheads/Camheads
    Last Post: 12-17-2013, 05:25 AM
