Results 1 to 15 of 23
Thread: 18k Mile Service Cost
    Approaching the 18,000 mile service. Dealer quoted $1600-$1900 depending on whether valves needed adjustment. Does that sound right?
    This is for a 2016 GTL.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Where are you located?
    Lee
    2022 R1250RS
    MOA # 30878
    Past BMW Bikes: 2016 R1200RS, 2011 K1300S, 2003 K1200RS, 1991 K75S, 1987 K75T, 1984 R100RT
    St. Louis.
    Booger Man boogerman's Avatar
    Nov 2018
    defiance, mo
    Holy s#$t. I live around StL. What are they going to do ? Seems very high. I had my 2013 GTL done there a few years back & it was no where near that. Do the oil and filter change yourself. Ask them to reuse the valve cover gasket if itís still in good shape. Valve check should be around $800-900. If thatís what they are getting for the 18k valve check Iíll push my 2018 GTL a few miles farther down the road before I have mine done. I like the guys at GW but not that much.
    May 2003
    SW Iowa
    Quote Originally Posted by boogerman View Post
    K bikes can normally go a lot of miles between valve checks.
    When we had K1300Ss with a similar engine to the K1600 we went about 30,000 miles before the first valve check and they did not need adjustment.
    They replaced the inner and outer valve cover gaskets and I was ok with that because it's really time consuming to get at them again if one happens to leak.
    To save money I changed our engine and final drive oil, changed the air filters and changed the brake fluid.
    Lee
    2022 R1250RS
    MOA # 30878
    Registered User jonnybow's Avatar
    Apr 2019
    Delaware
    A lot of recent and dated discussion on this very topic on the forum. 90% or more agree that the valve check that's called for at 18K is a big waste of money until you are in the 65k and up area. Do what you feel comfortable with of course but myself and a ton of other guys aren't wasting our money on the valve checks for a bit.
    Jon
    K1600GT & R1200GSA
    BMW MOA #220293
    Mehrten
    Nov 2004
    Arizona, USA
    Get a reference point...
    Not withstanding that the K bikes tend to stay well in spec, its good to get a reference point.
    Doing it yourself is a lot of bodywork but nothing really difficult.
    Filling the radiator back up is a bit of a job.
    And getting those damn coils off the plugs!
    Our 2019 K1600 GT Sport was spot on at the 18k service.
    If I would have kept her, I wasn't planning on another valve check for at least 24 to 36k miles, about the time new plugs would have been in order.
    As a reference point our past '08 K1200GT jumped its cam chain at around 40k.
    90k miles later at 130,000 the valves were still in spec, none had required adjusting since new!
    Same basic engine, just two more cylinders.
    Quote Originally Posted by larryk1100rs View Post
    I am getting my 18000mile service done on Oct 22nd at Gateway. They quoted me a price of $1923 dollars!
    Aug 2018
    Fargo, ND
    A friend of mine had his done at Engle Motors in Kansas City. I don't remember the price but it was well under $1,000, I vaguely remember him saying $600-$700, no shims needed. $2K is just a rip off. It takes less than a day, maybe a full day if they need to re-shim the valves. Do the math, what is their shop rate? $100/hour? 8 hours is $800 , plus some incidentals. I would call around.
    From the only real Fargo, ND!
    Nov 2018
    defiance, mo
    Quote Originally Posted by gspot View Post
    What are all services they doing for that price ? Surely more than just checking the valves. Do you do any work on your Big K like oil change,filters, final drives etc ?
    That was for the whole 18,000 mile service. I don't think I am going to get valves checked at 18,000 miles. Probably wait until 30,000 miles if I do not hit a deer and total it out .....ha ha .
    Biker gunnert's Avatar
    May 2008
    Catlett, VA
    It's you money... Feel free to just "give it away". NGK recommends changing their spark plugs every 100,000 MILES in a car. I checked the plugs in my '12 K1600GT @50,000 miles, they were fine. I've read/followed literally every K1600forum thread on this subject for over 9 years now. There have been less than 5 bikes total that required a valve adjustment and I question those posts. If my memory is correct none of those valve adjustments were on bikes with less than 50,000 miles.
    Duane
    NoVA
    '12 K1600GT
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Quote Originally Posted by gunnert View Post
    Duane
    +1 on what he said.
    Joe
    ďFate whispers to the warrior, 'You cannot withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    May 2018
    Massachusetts
    Don't know how labor charges run out in St. Louis, but I just had my 18K service done a couple of weeks ago, and the Dealer quoted me $1,100. The invoice was actually a little less than that even though they replaced a $75 part during the service. They also offered me free pick up and delivery from my house, 50 miles away. I'm very happy, plus they adjusted my noisy cam chain. The engine is very quiet now.
    18GrandAM
  1. 36,000 mile service for 96 R1100RT approximate cost
    By cycloneranger54 in forum Oilheads
    Last Post: 05-24-2017, 06:03 PM
  2. 600 mile service cost
    By pbarton in forum Wetheads
    Last Post: 04-11-2015, 10:42 PM
  3. Avg Cost of 12000 mile service on '08 GSA
    By adventurexpress in forum Hexheads/Camheads
    Last Post: 06-02-2013, 10:12 PM
  4. Cost of 6000 mile service for my F650GS
    By pjsbrown in forum Thumpers - F & G bikes
    Last Post: 03-04-2006, 02:19 PM
  5. Replies: 8
    Last Post: 08-09-2005, 11:13 PM
