Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 47
Thread: Cool garages and cool garage ideas!
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by BC1100S View Post
    I suspect this requirement is due to the fact that the silencer must be moved out of the way in order to remove the back wheel. Hard to do if that joint is seized.
    Yes that ball shape muffler clamp allows the muffler to be pivoted out of the way during a tire change.
    I never bothered to lube that clamp on our bikes.
    Lee
    2022 R1250RS
    MOA # 30878
    Past BMW Bikes: 2016 R1200RS, 2011 K1300S, 2003 K1200RS, 1991 K75S, 1987 K75T, 1984 R100RT
    Left Coast Rider
    Nov 2011
    Lee, how can you stand working in that cramped and crowded garage? And, correct me if I'm wrong, do you wheel the bikes through that double door in the winter? If yes....
    May 2003
    SW Iowa
    Most of the time the bikes are parked in the addition through the sliding door.
    We can park both cars and the bikes inside.
    To get the bikes out I have to move one car.
    Lee
    2022 R1250RS
    MOA # 30878
    Left Coast Rider
    Nov 2011
    Nice!
    Looking at this makes me think we should do a Rate My Garage series.
    Redneck Oregonian radiofun1's Avatar
    Dec 2009
    Ashland, Oregon
    Nice work and parking space.
    May 2003
    SW Iowa
    Last week I decided to repaint the main garage space.
    I need to learn how to epoxy the floor.
    The first year we lived here I used garage floor paint after a good scrubbing but it still started to bubble up the first winter with all the moisture from melting snow and ice.
    Lee
    2022 R1250RS
    MOA # 30878
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    You win the Innovator Of The Year Award!
    By the way, the absolute only solution to stopping the floor "paint: from bubbling from having melting snow on it is.... don't drive in snow. I never solved the problem in Fairbanks, but maybe with a high tech epoxy covering that is put on well prepared concrete. In the videos I've seen of pros applying it to old concrete, they grind a 32nd-16th of an inch off the top before application.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    May 2003
    SW Iowa
    Looks like I better leave it to the pros. Our house was built in 1969. Many years of oil and dirt.
    Lee
    2022 R1250RS
    MOA # 30878
    Left Coast Rider
    Nov 2011
    I'm sure that's caused you many years of sleepless nights.
    May 2003
    SW Iowa
    Hey, it's not easy being OCD
    Lee
    2022 R1250RS
    MOA # 30878
    Left Coast Rider
    Nov 2011
    I sorta know the feeling.
    Registered User mlytle's Avatar
    Oct 2015
    alexandria, va
    Diamond grinding the surface should be done even with new concrete if you are putting down top end commercial epoxy.
    That said, on my first shop I acid washed the new concrete and used Rust-Oleum two part epoxy paint. Was still perfect 15 years later when I moved.
    Marshall
    92 K75s, 94 K75s, 09 K1300s
    Aug 2018
    Fargo, ND
    I worked for company that sold epoxy floor coatings. We never recommended grinding the floor unless there was a previous coating that was a mess, or the floor was rough. Just degrease, acid etch and degrease again and you are good to go.
    I put down epoxy on my garage floor 25 years ago and it has held up well. but it needs a recoat.
    From the only real Fargo, ND!
    May 2003
    SW Iowa
    Quote Originally Posted by PoorUB View Post
    Thanks for that info.
    Lee
    2022 R1250RS
    MOA # 30878
    Aug 2018
    Fargo, ND
    You can rent a carbide scraper that mounts to a standard floor buffer. Any good rental place should have them. It will scrape off any old floor coating, and any little bumps. It will not level the floor.
    https://www.sunbeltrentals.com/equip...-tooth-driver/
    Applying epoxy isn't much different from any other paint job. The better the prep, the better the results. My garage had been used for auto repair for a few years, by me, before I decided to lay down some epoxy. All the greasy spots got soaked several times with mineral spirits, (paint thinner), then cleaned up with kitty litter, then a few washes with a good degreaser, then a couple etchings with muriatic acid, (this stuff is nasty so be careful and have the good air circulation. Then follow that up with a couple more degreasings to neutralize the acid. Let it dry good and apply like you would with any house paint. Mask the edges and edge in with a small brush and then use a roller on the main part of the floor. You may need a second coat. Some guys use and old pair of gold spikes to walk on the first coat and not leave foot prints. Generally you need to apply the second coat before the first sets up , right after it stops being tacky. If you wait too long you might need to wait a couple weeks, sand it lightly, wash, and apply the second coat.
  1. This Is Very Cool
    By daveh10st in forum Motorrad
    Last Post: 06-04-2016, 10:58 PM
  2. Cool GS Garage Accessory
    By KenDittrick in forum Gear
    Last Post: 02-17-2015, 12:33 PM
  3. Can't cool above 94F
    By queretaro in forum Motorrad
    Last Post: 09-19-2013, 03:15 AM
  4. cool
    By Gnome in forum Campfire
    Last Post: 07-13-2004, 08:25 PM
