stevenrankin
Active member
Stuff
All the proper colored and gauge wire is available as well as the good factory style terminals, everything needed to make a wire harness, if that is the path to choose. There is no need for scotch lock or AutoZone terminals. I have seen a couple of guys make some very nice one off wiring jobs on bikes. If you have the know how, patience and desire, you don't always need a factory harness.
Many long years ago, I was young and used the shortcuts available to get the job done and working. Some shortcuts are good and work, others not always. I found using scotch lock connectors and cheap crimp ons worked for a while, sometimes the life of the car, but when they failed, (more often than I cared) they made things difficult to repair.
I like the idea of adding a ground wire, my mind goes blank but I believe the /6 I helped install the factory signals on didn't have one. They grounded to the stalk. We did put a short pigtail on each to be sure they were grounded to good metal.
Good luck and enjoy. St.
