Results 1 to 8 of 8
Thread: Telelever & Front End Dive?
    Question Telelever & Front End Dive?
    My ‘«÷01 R1150GS was my first BMW. It felt strange at first but I grew to love the nearly-no-dive nature of the telelever front end.
    More recently I rode an ‘«÷02 Adventure and there does seem to be some front-end dive ‘«Ű maybe not as much as other brand bikes, but more than my ‘«÷01 GS. I can‘«÷t figure out why that specific Adventure dips more than my old ‘«£standard‘«ō GS. Suspect theories include:
    1) there is a problem with the ‘«÷02 Adventure that needs to be addressed
    2) not necessarily a problem, this is likely a set-up issue and can be tuned to preference
    3) not necessarily a problem, Adventures are supposed to have a bit more dive than the ‘«£standard‘«ō 1150GS
    Any thoughts on this? Thanks!
    (I‘«÷m a newbie to BMW MOA ‘«Ű I searched the forums and don‘«÷t see this specifically addressed ‘«Ű none-the-less, sorry if this is an old topic)
    Paul Brown
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    I would expect number 2 on your list is the case.
    Nevel let it be said that lack of experience or specific information kept anyone from responding to a post on the forum.
    Pass the mustard and UP THE REVOLUTION!
    25-MPH NEXT 1OO MILES PacWestGS's Avatar
    Aug 2004
    N47.06' 204" W122.33' 188" (PacNorthWet)
    Option #4
    Longer suspension travel and more compliant off-road springs.
    Option #5 More fuel at times.
    I ride an '02 'standard' with Ohlins which are different than the Showas in "Great" way.
    I recently learned again what brake-dive is with my F650GSD.
    "If you took the time to really get to know'd be wasting your time, because I'm exactly who you think I am"
    (Life comes at you pretty fast "Pay it Forward" - Have no regrets when the end happens)
    Tucson, AZ, & Madison, WI
    Here's my take:
    (1) Earles fork BMWs (1955-1969) would actually rise slightly under hard front braking.
    (2) Telescopic fork BMWs (1970-1995) would dive precipitously under hard front braking.
    (3) Telelever fork BMWs (1995-present) dive slightly under hard front braking. The factory could tune this out through revising fork geometry, but chose to keep some small amount of dive.
    Jeff Dean − BMW MOA Co-founder (1972)
    Tucson, Arizona, and Madison, Wisconsin
    Co-founder, 1972, of BMW MOA
    '17 R1200RT, '15 R1200RT, '67 R60/2, '69 R60US, '55 R67/3, '49 R24
    Nov 2005
    Calgary, Alberta
    The analyses that I have read indicate that BMW deliberately designed a bit of dive into their telelever front ends because most riders like that characteristic.
    I ride an '04 Adventure and I can get a small dive with the front shock at the weakest/softest setting but it can be tuned out by adjusting to your weight and riding conditions etc. At the second setting though it is practically gone.
    Jim Bud
    Sedalia, CO
    Just to scratch your head...
    Are you feeling front end dive, or rear end lift??
    Can you tell the difference??
    Jim Bud...
    I can tell the difference between front and rear yes...the pointy end goes forward right? I find it much easier to steer from the front
    On mine I can get the rear to lift if I adjust the rear shock just so, although it is for that reason that I keep the adjustments as good as possible to counterract that effect. A good observation as it is often over-looked. A lesson that I learned on this bike as on the UJM's it is somewhat hidden in amongst the real dive on the front.
