2001 R1100R with 7200 miles. Recently installed a AF-XIED (AFX) due to surging issues and after install the bike was cutting off and at times wouldn’t crank. Realized, after some help, the hall sensor was shot and during AFX install, while disconnecting the O2 sensor, I disturbed the hall sensor wiring which led to my issues.
GSaddict rewired the HS and I reinstalled. In addition, a valve clearance adjustments and TB sync was done. AFX changed the operation and drastically reduced the surging issue I had at approx 3500rpm. Currently have it at 7.
PROBLEM. Since I reinstalled the HS, with the newly installed AFX, the bike will not idle or run smooth for 1-2 minutes after startup. I have to use fast idle and also use the throttle continuously to keep rpms up, otherwise, rpms drop and the bike cuts off. After about a minute or so something magical happens and rpms level out at 3k with fast idle on. I turn off the fast idle and it runs at 1100rpms smoothly.
Runs great after this startup procedure but if I ride it for 5 mins, or for 1 hour, and turn it off and attempt a restart, the same thing happens even when the bike is warm.
Any ideas before I take this thing to a mechanic???
