jhall
BMWMOA #24809
Yesterday I went for a 250 mile ride. Upon initial startup, I noticed a light valve tick, that became louder along the way. By the time I returned home it was loud, and very noticable. It is only one valve, and I was too tired and too much heat upon return home, so did not bother to even figure out which cylinder it was coming from. About 7500 miles ago, I replaced all four rocker shaft needle bearings on the right side, and adjusted all valves, on left & right cylinders. I doubt it is valve adjustment, since valve clearances close with mileage, but anything is possible. I am looking forward to removing the rocker covers tomorrow to check it out. Will let y'all know what it turns out to be. Hopefully not rocker shaft bearings again. I bought all eight bearings before, but only changed out the right side. Need to get out in the garage early in the morning, before the heat comes. Will update later.
