Results 1 to 13 of 13
Thread: Squeak in front end of K1600GTL
    Aug 2019
    Ohio
    Anyone had issues with a squeak, coming from the front end ? Sounds like maybe front fork, shock area. It it present with front end movement with road surface.
    Dec 2007
    Indiana
    Assuming a telelever suspension bike...I''ll be thinking the rubber bushing in shock mount (can produce a pretty good squeak) area needs a little anti-squeak applied. Or put out a mouse trap.
    '22 R1250RT '93 R100RS
    MOA #46783
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    A lower shock mount bolt at the telelever that needs greasing will squeak.
    Liaison 20774's Avatar
    marv-lou -
    If you can provide more details as to the model of bike, I can add that to the title as well as move the thread to the appropriate forum area. From your past posts, you mention a K1600 GTL...is that the bike?
    Thx...
    Left Coast Rider
    Nov 2011
    A mouse in the saddlebag? Hey, its as good a guess as any!
    Oh, I see now that its in the front end. Nevermind.
    Mar 2006
    Spartanburg SC
    As I get older, it seems that more squeaks and other noises are coming from the rear end!
    Somebody had to say it....
    Quote Originally Posted by DaveSlash5 View Post
    As I get older, it seems that more squeaks and other noises are coming from my rear end!
    Aug 2019
    Ohio
    Thanks. I’ll look @ the seals, thought it might b something like that. Hoping it wasn’t a major repair
    & yes… it the k 1600 gtl
    Aug 2019
    Ohio
    thanks. ill check it
    Registered User jonnybow's Avatar
    Apr 2019
    Delaware
    Well known issue on most older model K16's. Seems most guys have used SiliKroil lubricant on the front end and have eliminated any squeaking.
    You can probably find it online or at your local john Deere dealer.
    Jon
    K1600GT & R1200GSA
    BMW MOA #220293
    squeak
    Quote Originally Posted by jonnybow View Post
    it's not even that complex. The upper end of the shock at the front has some kind of a collar or the shock bushing that gets "unlubricated". I got a spray can of 3 in 1 lubricant and a long nozzle tube and did a couple of squirts at the top of the shock and at the upper pivot point. No more squeak. I don't know if it is the wiper for the shock or the upper bushing rubber but I haven't had the problem again.
    Registered User tol99's Avatar
    Jun 2019
    Red Wing, MN
    Eliminate the Squeak
    Here is a short video on how I eliminated the front suspension squeak on my K1600GTL. I hope this is helpful to someone. https://youtu.be/N5Pb8hiemZk
    1985 K100RT, 2006 K1200GT, 2015 K1600GTL
    1994 GL1500SE
    2005 KLR650
    Lights, camera, action! Thanks Tom for providing some visuals for this! As stated at the end of the video, "Stupid, Corny and Poorly Made Motorsports Videos". Can't be that stupid if it fixes the problem!!
  1. 2018 K1600GTL - Front DIN Power Outlet
    By PhilStearns in forum Straight 6 K1600 GT/GTL/B
    Last Post: 04-02-2020, 05:22 PM
  2. The Dreaded Front End Squeak!
    By ukexile in forum Straight 6 K1600 GT/GTL/B
    Last Post: 12-18-2017, 10:36 PM
  3. OK...Who's got that hideoous front end squeak!!!
    By mrmrsnct in forum Straight 6 K1600 GT/GTL/B
    Last Post: 10-10-2017, 11:31 PM
  4. Front brake drag and squeak '77 R100S.
    By georgej in forum Airheads
    Last Post: 07-13-2015, 05:36 PM
  5. K75 front brake squeak/chirp
    By barooo in forum Flying Brick K-bikes
    Last Post: 08-23-2009, 02:22 PM
