Results 1 to 4 of 4
Thread: 1996 R1100RT How to tie down the R1100RT for trailering.
    Aug 2017
    Champlin MN
    Hi All I'm in the process of moving from Minnesota to Mt. Juliet Tennessee. I'll be trailering my bikes, one being the RT, and was planning on strapping the front end down the traditional way, straps around the lower triple clamps. But of course that won't work on the RT. So, it looks like the strapping point is around the fork legs, just above the cross brace. see pic. For those of you experienced at this, is this correct?
    Mansfield,MA
    I like to “close” the open hook with good quality electrical tape so nothing comes undone on a recoil bounce.
    A good thread found using the Tag Cloud is here-
    https://forums.bmwmoa.org/showthread...orycle-trailer
    Hope you don’t miss the deep freeze too much.
    Mod Squad
    2009 F800GS 1994 TW200
    Feb 2005
    Trinity, NC
    Yes. Down by the front forks is right. Just don’t pinch the brake hose.
    Do a search for tiedown2.pdf. You should get a link for that document showing tie down of an Oilhead, or maybe a Chromehead.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Aug 2017
    Champlin MN
    Thanks for the input. I did find tiedown2.pdf, very good. And, I will definitely not miss the cold or shoveling the snow.. We had two days this past winter when it hit -30F, real temp not wind chill.
  1. 1996 R1100RT Surging
    By oldcarman in forum Oilheads
    Last Post: 03-28-2020, 09:42 PM
  2. 1996 R1100RT Top Case Pad
    Last Post: 12-26-2018, 02:47 AM
  3. 1996 vs 2000 R1100RT
    By landfellow in forum Oilheads
    Last Post: 06-20-2011, 03:21 PM
  4. R1100RT trailering
    By craiglascruces in forum Oilheads
    Last Post: 08-01-2005, 06:11 PM
  5. r1100rt trailering
    By craiglascruces in forum Gear
    Last Post: 07-27-2005, 10:05 PM
