Results 1 to 9 of 9
Thread: Kick Stand Extension for a 94 R 1100 RS
    Kawa Afterthought weschmann's Avatar
    May 2012
    DeSoto MO
    Recently changed old 9 year old Michelin PR 3 tires on my 94 RS . Couldnít find any Michelin 18 inch tires so went with the Metzler 888 in the 160/60 18 rear and 120/70/R17 in front. It seems these tires are taller somewhat as I have very little clearance from the ground when on center stand, where in the past the front would spin freely. No big deal I think, but find the additional quarter inch seems to really put the bike on a tilt when on the side stand. Any suggestions for a kickstand extension other than carrying a piece of wood to stick under it? Tires run great and no rubbing but Iím not completely flat footed anymore and donít think Iíve shrunk another half inch in a couple days. 😀.
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    I had a different issue with the side stand on my Ď00 RS. I just wasnít comfortable that it would support the bike on soft ground or when loaded, so I cut out a foot an welded it to the bottom of the stand. I then ground it to fit by cornering. All good now but you might consider adding a foot, for support as well as adding length to the stand. Iíve also seen folks cut the stand and add a sleeve, again welding it, to add a little length.
    Gary Phillips - #6322
    Wildland Firefighter, Retired, Riggins, ID
    Heartland Moto Locos BMW Riders
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
    Mansfield,MA
    Quite a few side stand threads via the Tag Cloud. Here is one.
    https://forums.bmwmoa.org/showthread...e-Stand-Length
    Mod Squad
    2009 F800GS 1994 TW200
    May 2012
    DeSoto MO
    Thanks for the direction. I don't have a welder but do have the ability to cut, tap and add bolt spacer. Excellent idea. I'll have to learn how to use the Tag Cloud on the forum as I have been using the search column but have poor results. Something new to learn.😀
    Jerry Emhoff
    Oct 2007
    southwest Michigan
    I added a hockey puck to the bottom of my sidestand on my 96 RT and love it. Iím not home so I donít have a pic. I used a router to inset the foot into the top of the puck and used stainless screws to attach it. I also had to trim the outside edge so it would rest properly in the up position.
    Winter is coming
    May 2012
    DeSoto MO
    Quote Originally Posted by Mirider View Post
    👍. I'll try this first.
    Liaison 20774's Avatar
    Examples:
    https://forums.bmwmoa.org/showthread...l=1#post156067
    Near bottom of this page:
    http://www.kbikeparts.com/classickbi...100rs_mods.htm
    This site had multiple "extensions" for various bikes...here's just one:
    https://www.motorcycleparts-hornig.c...rgement-2.html
    Mansfield,MA
    Quote Originally Posted by weschmann View Post
    Great pictorial on using the Tag Cloud here-
    https://forums.bmwmoa.org/showthread...Tag-Cloud-quot
    Really a helpful tool as it ďautomaticallyĒ starts to fill while you type and allows you to see the best options.
    Mod Squad
    May 2012
    DeSoto MO
    OMG Thanks. How I forgot this great option, I cannot say, but new found, lost knowledge relearned is a bonus to each bonus day of retirement😀🙏
  1. Center Stand and Kick Stand Wear
    By 196097 in forum Flying Brick K-bikes
    Last Post: 05-14-2018, 02:08 AM
  2. GS kick stand
    By btadjalli in forum Thumpers - F & G bikes
    Last Post: 10-02-2011, 05:44 PM
  3. 95 R1100R Kick stand
    By Ctrod in forum Oilheads
    Last Post: 03-29-2010, 11:45 PM
  4. Kick stand removal
    By ggfossen in forum Hexheads/Camheads
    Last Post: 06-23-2007, 11:42 PM
