Results 1 to 3 of 3
Thread: Gen light stays on at low and hi revs on '67 R 60
Hybrid View
    Hi All-
    I have indirectly read some generator posts on this forum before but maybe not for this issue -
    My generator light on my 1967 R60/US was going on at hi revs. I changed the brushes and the light went out for a 2 hour ride at all revs so it seemed to work. Then the problem started up again. I cleaned the rotor as well and no go.
    Any thoughts? (FYI - I am electronically challenged)- Thanks to all.
    Liaison 20774's Avatar
    Welcome to the forum! I will move this to the Vintage sub forum after a bit of time...
    I've not fiddled much with these older systems, but it sounds like maybe the brushes are not moving easily in their holders. Or the springs that push the brushes against the slips rings are not tensioned correctly. It's possible that the regulator contacts are dirty...sliding a thin piece of paper like a business card across the contacts could clean them up.
    There is booklet that describes the /2 charging system on line:
    https://www.snafu.org/restore/uandm_bmw_v1.pdf
    A newer version with colored diagrams is available at Bench Mark Works.
    Thanks very much Kurt. New to the Forum so I'll look for the Vintage sub forum next time. Thanks also for the link. I'll check it out and post any success.
    Best-
  1. Oil light stays on .....
    By nevada72 in forum Airheads
    Last Post: 04-22-2018, 12:59 PM
  2. gen light stays on
    By CANADIANSTEVE in forum Airheads
    Last Post: 09-22-2009, 09:22 PM
  3. Fuel light stays on ???
    By jackyd in forum Oilheads
    Last Post: 12-14-2006, 05:33 PM
  4. Altaernator Light stays on
    By jethridge in forum Airheads
    Last Post: 10-05-2006, 05:37 PM
  5. Red light on dash stays on now?
    By acehosedme in forum Flying Brick K-bikes
    Last Post: 05-27-2004, 01:27 PM
